Question about Motorola Walkie Talkie 2-Way Radio
Model SX750CR will send OK, can not receive.
I have a set of SX750CR that can send audio to other units, but they both will not receive any audio. Did not get an owners manual, is there a mute feature or something else that may cause this?
Thanks
Scott
    Master:
  • 518 Answers
There's no mute feature on 2-ways.
Will the 2 units work with each other? If so, then it could be an issue with the squelch codes.
There's usually a push button on those units that will "open" the squelch momentarily and you should then hear squelch noise and maybe get a green light to tell you squelch is open. If you have that and don't hear the noise, it could be a bad speaker.
Geno
Posted on Aug 01, 2008
How to reset onkyo HT-R395
Hi, please see procedure below.
Resetting the main unit Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this. 1 Switch the receiver into standby. 2 While holding down STEREO, press and hold ?ON/STANDBY for about two seconds. 3 When you see RESET? appear in the display, press SURROUND. OK? shows in the display. 4 Press DSP to confirm. OK appears in the display to indicate that the receiver has been reset to the factory default settings. Important • If the Standby Through is not set to OFF, you may not be able to initialize the unit.
Dec 31, 2016 | Onkyo Audio Players & Recorders
Our turntable is not producing any sound even though we have changed the speakers
Be sure the audio-out leads are connected properly to the receiver. They usually will work ok connected to the aux. plugs. Be sure the selector on the front of receiver is set to aux as well. Check the cartridge output wires to insure they are connected to the cartridge ok. If you have the receiver powered up and have the proper settings on the front of the receiver, you should get a little static sound when plugging the audio output leads into their respective input jacks on the receiver.
Feb 21, 2015 | Audio Players & Recorders
Digital Audio Input isn't working
try to reset the receiver (note: all your settings will be lost) :
1 Switch off the unit using the main unit's power switch.
2 Hold the following SPEAKER A button and B button, and turn the main unit's power switch.
3 Check that the entire display is flashing with an interval of about 1 second, and release your fingers from the 2 buttons and the microprocessor will be initialize
assign inputs if necessory and check sound again. If no luck your receiver most likely has a problem with digital board and you need to send it to a repair facility.
Dec 18, 2011 | Denon AVR-785 Receiver
Need owners manuel for yamaha receiver model no. tcd cc5
Hello
Send your Email address by Fixya to me. I've the user manual for Yamaha CC-5. I can't send it to you by this window as it does not allow me to upload pdf files by it. I'll send a copy of it by return mail, if you inform me where should I send it. OK.
Nov 13, 2011 | Audio Players & Recorders
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
My Onkyo TX-SR505 is not set up properly. (and i have no idea where the maual is) I cant seem to get any sound to work for the tv OR my Wii. Help? i can get video on the Vcr/dvd slot, but no audio.It use...
Hello
Send your email address to me by Fixya. I've the user manual of your Onkyo model. I'll send a copy or it to you by return mail. I can't send it to you by this site as it exceeds the upload capacity of this site. OK.
Apr 23, 2011 | Audio Players & Recorders
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
Distorted audio into AG_DVC7 Digital camera from Mixer Aux send
set the camera audio switch to line, not mic feed. This switch is on the camera. Adjust the audio gain to -60db in the menu settings.
Mar 27, 2009 | Panasonic Proline AG-DVC7 Mini DV Digital...
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Radio Communications Logo
432 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
