Question about Sony RDR-VX521 DVD Recorder/VCR
Some discs play, some don't on my Sony RDR-VX521. I usually get a "This disc cannot be played or recorded" message after it tries to 'load' for some time. It isn't just burned DVDs this happens with, and all the DVDs are in good shape - no warping, scratches, etc. Help!
raverbaby
  • 59 Answers
SOURCE: I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Posted on Apr 08, 2007
jackboy
  • 2985 Answers
SOURCE: Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Posted on Jul 01, 2007
mastersaintx
  • 928 Answers
SOURCE: Can't play Burned DVD's
This is because when you burn a DVD and want to use it on another unit you have to finalize it. Especially from another device such as your computer. You should have the option on your computer to finalize or make disc compatible.
Please message back if you need further assistance
Posted on Sep 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Posted on Jan 04, 2009
leecom72
  • 4806 Answers
SOURCE: unlocking the region code
Hi there
There is no region hack for that model just for the moment, you can pay however but invalidate the warranty.
Good luck
Posted on Jan 11, 2009
I have a sony rdr-gxd455 dvd recorder that is supposed to play DVD-RW and DVD+RW discs. Everytime I load one of these discs, I get a Disc Error, even for one that was not used before.
If you get a disc error, it could be dirt on the lens. So you should try cleaning it. Generally this effect all discs, but your player might be sensitive so only does it on new discs. You could have a bought a bunch of fake discs too, looking genuine, but useless!
Lastly a fault on the player.
Sep 19, 2016 | Sony RDR-GXD455 DVD Recorder
RDR-VX560 have recorded about 250 programs, on DVD-R and DVD+RW discs. Recently I went back and made sure that all had been finalized. I then checked out their operation on both the recorder and my new...
I'm sorry that the discs are not being able to read using either Computer nor with the Recorder itself. Based on the information you have provided, it appears that the discs are corrupted. Please check whether other discs are playing fine with the Recorder and computer to make sure that the drives are fine. If Recorder and Computer playing fine other discs, we can confirm that the issue is with the discs itself.
Clean the discs using a soft cloth starting from center to straight toward edge.
Use any software recovery software to recover the data. I have provided a link where you can download one for free. Click here to download the data recovery software.
Clean the discs by following the below step.
Thus cleaning the disk should always be your first move. Run warm water over the damaged disk to remove dust. If there is stubborn dirt or grease on the disk, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Anytime you rub or wipe a CD or DVD, you should do so by starting at or near the center of the disk and rubbing straight outward toward the edge to prevent further scratching. Shake the water off and let the disk air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
Now play the discs directly on the computer and recorder. If the issue persists, try again using the recovery software.
I hope the information helpful, please let me know if you require any clarifications.
Thanks for understanding.
Jan 18, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
hello,
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
Jun 03, 2010 | Sony RDR-VX420 DVD Recorder/VCR
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Disc error message
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Sony RDR-VX521 DVD Recorder/VCR Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
