Question about Fuji FinePix S7000 Digital Camera
My fuji S7000 automatically shut down (Switched off) frequently while I am taking pictures. Let me know what is the problem?
If the batteries are OK, then the shutdown has a simply-cured physical cause. Open the CF card door and look for a small square opening at the bottom of the door. Look inside this and there should be a small plastic 'plate' or flap. DO NOT TRY PUSHING IT WITH A PENCIL OR NEEDLE etc. The bad news is that if you DO see that flap inside the little square opening, then your problem probably lies elsewhere. But if what you see looks like the tip of a pencil, then THAT'S your problem. The flap is there to keep dust out. It's thickness is needed so that closing the door operates the switch. Without it, the door seems to be open and the camera shuts down. If you can find an alternative for that small plate, your problem should be solved. One solution is to attach a small (about 3mm square) piece of foam pad to the tip of the protrusion inside the square. A typical example for this type of foam pad is what scrapbookers fasten photos into their albums. There will be other solutions - but the loss of that flap will be the cause.
Posted on Jul 26, 2015
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
Posted on Mar 09, 2009
SOURCE: Fuji S7000 shuts itself down...without a reason
was using s7000, on the view screen, it looked like a piece of paper kept coming down the screen, the more pic's I took, the lower it came down, finally covering the screen completely. Also the batteries, will not last but maybe 15 minutes.
Posted on Jan 22, 2010
  • 11967 Answers
SOURCE: Need - software for Fuji S7000 Digi camera
You don't need the software. Just use a card reader to download to a folder you create on your desktop.
Posted on Jul 09, 2010
Fuji digital camera service centre chennai
Are you sure you are using fully loaded battery's, because most camera's will automaticly shut down, when the battery voltage drops under a certain voltage. Sure your battery is still in tip top condition?
Don't use NiCD batteries, only alkaline and Ni-MH rechargable batteries should be used.
Page 15 of the manual shows how you can find out if you are using correct (with enough charge) batteries.
Oct 31, 2013 | Fuji FinePix Cameras
My fuji s7000 zoom has coloured wavey lines when turned on. It goes back to normal intermitantly but at the moment it is constant Ian
Hi Ian.
If the lines are reproduced in the pictures taken, then the image sensor located behind the lens is starting to fail. The problem will usually get progressively worse until you won't be able to shoot regular pictures anymore.
Call Fuji and ask about repair. You can get a quote from a third party here: Repair.
Regards.
Ginko
May 27, 2011 | Fuji FinePix S7000 Digital Camera
My camera only shows half a picture after I take the picture on the little screen and if I keep taking pictures it goes all white? it's not the batteries. thank you
Hello - from a fellow Fuji user.
I'm assuming the pictures are looking OK on the PC when you download. If so this will be a LCD fault.
If NOT and the downloaded pictures are the same on the screen and the PC , then it looks like a sensor problem (CCD chip). I just did a quick search on the google.co.uk site and could only find 4 complaints , so it's pretty rare.
Try re-formatting the SD card just to eliminate that from the equation --
http://forums.steves-digicams.com/fujifilm/152895-fuji-finepix-s7000.html
Plus there are S7000 forums to ask like http://forums.techguy.org/digital-photography-imaging/562485-fuji-finepix-s7000-problem.html
Hope this helps , but , if it's a sensor problem I hope it's still under warrantee -- Ray
Jan 14, 2011 | Fuji FinePix S7000 Digital Camera
When i take a picture and down load onto my computer, the picture size is too big on the computer screen.
You can edit picture sizes in various graphics programs, but if you just want to view the full picture on your screen then there are a number of viewers that will automatically size it to fit. The one I like is called FastStone. It is a free program you can download from download.com.
Oct 19, 2010 | Fuji FinePix S7000 Digital Camera
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Dec 31, 2008 | Fuji FinePix S7000 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Fuji fine pix s7000 flash not working
Check to see if the flash has been set to a lower power or underexposes via a +/- setting. If not, warranty repair unless the camera has been damaged.
Sep 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji S7000 Time-out issue
I think I Had that problem too. mine also quite suddenly started showing low battery even on new ones... it seemed better with non-rechargeable types. Now the reason I'm on this site is as the lens doesn't open.
Jun 06, 2007 | Fuji FinePix S7000 Digital Camera
Camera shuts down when I go to take pic mode
Ahhhhh! I have the same problem occuring!! I cleaned all of the battery terminals and replaced the batteries, and STILL have this problem, although not as frequent. It always happens when I take the best pics, the image shows on the screen for a fraction of a second, and then the whole camera shuts off. Again, I can play back images with no problem. What's the deal here?? It's become so frustrating that I just want to throw the camera in the garbage. It has been such a good camera up until this point. PLEASE, someone help us here!!!
Aug 30, 2006 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
177 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
