Printer keeps saying it's jammed when there is no paper in it. Printer is a lexmark x7675. Which screws do i need to unscrew?
    Scholar:
  • 104 Answers
Look at the rollers and near the print cartridges that stay open when the paper isn't moving along..that compress or lift as the paper is fed. Did you overload the paper tray? sometimes that forces the tab open way deep. A flashlight and plastic fork is all you should need. If it was used alot the hear could have bent a piece of plastic but that gets into the corner cases
Here's the user's manual but not sure if it will help but screws should NOT be the issue , most all of these problems are related to plastic or residue sticking the switch open so it thinks the paper is inside...check print cartridges...could be a scrap of a piece
http://www.lexmark.com/publications/pdfs/2007/7600/v7597795_en.pdf
Posted on Mar 14, 2011
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
I have a lexmark x7675, when ever I try to copy or print anything, the paper feed but it then stop and the printer says that there is a paper jammed, but there isn't any. I tried several times and the...
you have to open up the printer using a every day Phillips screw driver, once you have done that you either need to rotate the roller by hand or look for something stuck in rollers that you cant see under normal circumstances
Mar 06, 2011 | Lexmark X7675 Wireless All-in-One Printer
How will i install my lexmark x7675 printer to my PC so that i can print?
I dont; have the book for my printer, lexmark x7675; I NEED HELP TO INSTILL IT
Aug 11, 2010 | Lexmark X7675 Wireless All-in-One Printer
Have lexmark x7675 installed factory new cartridges still reporting out of ink
Hello. The cartridges may not be seated properly or just needs cleaning. Remove the cartridges from the printer. Make sure the protective nozzle tape is already removed. Wipe the nozzles of the cartridges using a damp paper towel. Unplug printer from power source, plug it back in after 10-15 seconds. When the printer's ready, reload one cartridge first. Close the cover, check if "out of ink" message is displayed. If not, proceed on loading the other cartridge. This is to check which cartridge is causing the problem. Try this steps maybe 2 or 3 times until the printer recognizes the cartridges. If problem persists, I strongly advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). You probably got defective cartridges.
Apr 21, 2010 | Lexmark X7675 Wireless All-in-One Printer
My Lexmark X7675 is pulling the paper to the left when printing causing the paper to Jam. How do I fix this?
Hello sir; Check the paper tray at the bottom there should be have something especial on the left side of the tray.
Feb 08, 2010 | Lexmark X7675 Wireless All-in-One Printer
Lexmark X7675 error: Paper Jam (on printer control panel). Have turned off/unplugged several times, occasionally clears error, but it comes back. Sometimes just as paper has fed about 2 inches, sometimes...
Remove the cartridges. see any bits of paper left behind. Replace the cartridges. You will be asked to align again. Do this.
Hopefully, this will work
Good luck
luciana44
Jan 25, 2010 | Lexmark X5470 All-In-One InkJet Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
My lexmark x4550 keeps rejecting paper and says vlear paper jam
I'm not sure what step have you taken to remove the paper. However in general you may need to shut down the printer properly. Please refer to below article that might be helpful for paper jam issue on LExmark printer.
http://etech.maiila.com/?p=25
Apr 29, 2008 | Office Equipment & Supplies
134 people viewed this question
k24674
jasbo
jasbo
