My battery is 6 months old but once i connect my laptop after 2months it flashing orange and green.once i click on batter it shows no battery is detected. I have removed and reconnect the battery but it showing flashing orange and green
    Problem Solver:
  • 10 Answers
Your battery has likely suffered from a deep discharge and will need to be replaced. One trick you can try however is to remove the battery, place it in an air-tight baggy, and put it in the freezer for ~4-6 hours. Remove it and let it sit at room temperature for a few hours before putting it back in; with any luck it'll take a charge and you won't need to replace it.
Posted on Mar 14, 2011
Orange light mean
The orange light indicates its stuck in charging mode.
Hold volume down and power for 15 seconds, you should see the bottom buttons flash a few times and it will go into recovery mode.
Use volume keys to highlight restart phone and press power once.
Oct 12, 2013 | HTC Cell Phones
Plugged it in and there is power going to the computer (orange batter light is flashing) but the green power button is not lit and the computer is not booting up. I should not need the battery if plugged...
You're correct. The laptop should power up when connected with AC adapter with or without the battery being installed. If you still have no power, the power supply on the laptop may be bad.
Feb 20, 2011 | Sony Vaio PCG FXA36 Laptop Universal AC...
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Canon S450 not responding
Try resetting the printer like this
Canon S450 Printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Jul 05, 2008 | Canon BJC S450 InkJet Printer
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
