Question about Dometic Rooftop RV Air Conditioner
Air conditioner leaks/drips from filter inside travel trailer
I have a 2000 Rockwood Roo that has an issue with water dripping inside the trailer from the air conditioner's filter when running the ac unit?
  • 2 more comments
  • bnvb Aug 04, 2008
    duotherm dripping water from ceiling vents and now the thermostat runs aux. heat (we don't have), and will not run the air.
    Thermostat reset as if we have several zones. book says the manufacturer sets this so gives no info.
  • efulton4 Aug 04, 2008
    leaking water inside camper when ac is running
  • msucheermom Aug 17, 2008
    Duo Therm Air Conditioning unit is leaking water inside my motorhome. It is much worse when it rains; however, it leaks regardless of the weather. The back unit does not leak at all.
  • samcc Aug 24, 2008
    we have a almost new ac in our pop up that is a carrier ac, and it leaks inside the camper when it is on also. My husband doesn`t really know what to do.
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
Posted on Aug 14, 2008
The drain is stoped up/ or something is blocking the drain causing the water to run over the drain pan then the water will run in the camper through the filter -take the cover of and check to see if something is blocking the drain
Posted on Sep 09, 2009
  • Dometic Master
  • 6,674 Answers
Got to go with JGRV on this one. Try snugging down the bolts that pull the upper unit down to roof, and also have a good look at the gasket/seal at roof, when looking up through. These units have been known to have cracked trays, which would require close inspection from up top with cover off. When you take the cover off upper unit (roof) be aware that you will most likely be met by a bunch of Mudwasps &/or yellowjacket bees, so have spray ready, or wait until cloudy day, when they are not so lively.Make sure the mudwasps didn't build nests in such a way that they have dammed up the run off of the condensation from unit, and make sure all your drain holes are open. I have been told that an RV bathtub repair kit has been used on occasion to try & repair the crack, with some success, but personally, I wouldn't waste my time. If i was going to try anything, I'd probably try the spray aerosol "stop leak" that they use on the plastic eavetrouphs for $5-$6 / can, after cleaning area thoroughly, and let it sit for 24 hrs, and turn unit on and see what happens, if leak not stopped, I'm only out a few bucks & an hour of my time.Then I'd start pricing another unit.Keep in mind in my experience Coleman are less likely to have the cracked tray, as they use styrofoam in most cases, but I have had the odd coleman do it too, just not as many as dometic.
Posted on Aug 27, 2008
I have water drips from the filter on my dometic ac. Then when you change the settings or turn unit off it drains more water. I noticed a lot of condensation in the area of the coil foam housing
Sounds like unit is too small or there is too high of humidity. An A/C unit draws water out of the air as it absorbs the heat from the room. If the room is too big or there is too high of humidity the evaporator will freeze the moister and ice will build up then it will drip when turned off as the ice melts. As a fix, You can get a bigger unit, use a dehumidifier ( which works the same as A/C), or start the A/C at a warmer temp.and turn down gradually as air moisture disappears.
Sep 16, 2014 | Dometic Rooftop RV Air Conditioner
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
Water dripping from air conditioner
It's because of non-maintained air conditioner. Clean air filter, indoor coil, blower wheel and also drain pan. Insulate freon pipelines properly and tightly. After that run the a/c. If still water dripping. Check indoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gas pressure. If less, there will be ice formation over the coil and water dripping will be there when it melting. If short of gas, check for leak and rectify. Thanks. Helpful?
Jan 16, 2011 | Fujitsu Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
How do you get the ac to stop leaking water inside the window?
The a/c could be slightly leaning toward the inside letting the water drip in or the drain hole which allows the water to drip outside could be stopped up. Find the hole and blow through it with compressed air to unstop it.
Jul 25, 2010 | Goldstar GW-HD5000 Window Air Conditioner
Air conditioner condensation is leaking in the car
It is normal for water (condensation) to drip from the car when the air conditioner has been running. This is just a natural reaction of the cool inside meeting the warm outside air. Water collects on teh outside of the condensor and drips down. Nothing to be concerned about.
Jul 18, 2010 | 2000 Toyota Camry Solara
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
2,945 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
