Question about Kitchen Appliances - Others
I have just purchased Jan 2011 a Bellini 1.7ltr Quiet Boil Kettle Model BTEK80. Unfortunately when pouring the water from the kettle once it has boiled and turned off - the steam escapes from the closed lid and scalds my hand that is holding the kettle as I pour. Very very dangerous!! Can't find who to claim warranty through - purchased from Target shop. I feel this is a design fault and people should be warned. I would also like my money back. Whom should I contact?
jerryg50
  • 1667 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
SOURCE: light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Posted on Feb 21, 2009
homemender
  • 158 Answers
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Posted on Dec 23, 2010
SOURCE: water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Posted on Dec 25, 2010
  • 6771 Answers
SOURCE: I have a new Bellini
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
Posted on Mar 13, 2011
How do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
The lining of the kettle on the inside bottom is boiling away. What is it made of and is this dangerous?
Stainless Steel doesn't boil away. What you're seeing is the mineral deposits (mostly calcium) left behind from heating the heavy water you're pouring into the kettle. Descale it, pour it out and rinse every month or when it gets bad if you like. These deposits won't hurt you but looks nasty. Another option is to use filtered water instead of tap water. Hope this helps a little...
Oct 17, 2011 | Oster 5965 Electric Kettle
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 | Bosch Irons
I brought a bellini kettle from target 2 months ago and the lid wont stay shut, now target wont exchange the kettle as i dont have the receipt any more and its a quiet boil kettle and i canot find the...
The OP manual should have some contact info printed in it somewhere. If not, contact Target to find out who the supplier is. Call the supplier and ask how to contact Bellini.
Sep 03, 2017 | Kitchen Appliances - Others
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Mar 13, 2011 | Kitchen Appliances - Others
I bought the Russell Hobbs Whisper Kettle expecting it to boil quietly. Wrong. It is quite the opposite. Not sure if I can take it back due to "false advertising"??
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
Feb 23, 2011 | Russell Hobbs RHOK3123 Cordless Electric...
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
Light switch on Breville SK500-XL Kettle
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Kitchen Appliances - Others Logo
75 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
