Question about Bernina Artista 180
My Bernina 180 marchine becomes warm on the work service (the lower part on the right side of the pressure feet) and also on the top of the machine. Could it be the motor?
    Scholar:
  • 89 Answers
Dont think it would be the motor the moter is on the right side below the handwheel, you can see the vent.
Could it just be the light bulb, they get very hot.
The motor on that machine is solid, never had a bad one.
When you say warm do you meen HOT, there is going to be heat generated from the motor, light and movent that goes on it there this is normal.
Posted on Mar 17, 2011
Is the Bernina 1230 a low shank or high shank machine?
BEWARE! Bernina machines take a special Bernina-only foot, and even the older Bernina mechanical feet will not fit the newer Berninas, and vice versa.
For the most part, your 1260 uses the old style presser foot--BUT be sure to check as there are some old style that will NOT work on your machine. (Be sure to CONFIRM whether it will work on your machine as I believe the 1260 has some specifics that will not take all old style.) Red marked presser feet are only new style (ie computerized machines). The difference is in how the presser foot is designed at the top where it attaches to the machine. Your Bernina dealer generally carries both the old and new style. BEFORE you buy, be sure to ask whether you are getting the right foot for the 1260!
Look at the top of these presser feet so you can recognize what you need. You are probably safe buying the presser feet that have the 2 pegs at the top (if it has solid peg across the top, it may not work):
http://www.sewingpartsonline.com/bernina-1260-sewing-machine-parts.aspx#filter:ptype_gmcfeed_1:$2520Presser$2520Feet
Bernina Presser Feet (presser foot guide)
You can use snap-on feet BUT you still need a Bernina Adapter in order to do so.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjY-NSbrLvUAhUr1oMKHVIDAsYQFghUMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FProducts-US%2FBERNINA-products%2FAccessories%2FPresser-feet&usg=AFQjCNFMl-Fd3gweu5nM7Y9UqKmdz-fR7Q
Jun 13, 2017 | Bernina Sewing Machines
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
Jun 05, 2016 | Bernina Artista 180
How do I drop the feed on my Bernina 180?
On the right side of the machine is a square button near bottom of machine. Push it in until it stays in. That is the way to lower feed dogs
Feb 18, 2015 | Bernina Artista 180
How do I lower the feed dog on m Bernnia 180
Push in the square button on the right side of machine until it clicks. Then push in again until it u clicks. The feed dogs will raise once the machine starts to sew again
Presser foot on bernina 180 won't go all the way down
Could be a number of things ... does the foot-lift lever go all the way down when you lower the foot and is it unusually 'floppy' when you lower it. There is a small spring inside that should keep tension on the lever and these can ping off if you inadvertently let the foot drop under its own pressure instead of letting it down slowly onto the fabric (they're a nightmare to put back, too !) ... if it has come off, it may be jammed in the foot lifter mechanism. It's also possible that the foot lifter has shifted on the foot bar, in which case it really needs to be looked-at by a qualified Bernina service agent. When raised, there should be a gap of 7.5mm between the bottom of the foot and the top of the stitch plate - if much more than this, it indicates that the adjuster has shifted and you'll need to get it looked-at professionally.
Oct 28, 2011 | Bernina Artista 180
How to I determine the hours on my bernina 180 and on the embroidery module?
With the machine off, hold down the 'CLR' button and turn on the machine still holding down the button. On the lower right hand side of the screen that will appear is a clock symbol, next to it is the number of hours on the machine since the last service.
Oct 21, 2010 | Bernina Artista 180
Bernina artista 180 keeps warning to check top thread and it is threaded right
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Mar 25, 2010 | Bernina Artista 180
THE REVERSE STITCH WORKS SOMETIME AND SOMETIME IT DON'T
If it has been a while since the machine was serviced, the lubricant my be gummed up - warm (not hot) the area with a hair dryer to see if the switch will work as it should.
If this does not help, the machine will need to be serviced by an authorized Bernina tech.
Mar 24, 2010 | Bernina Artista 180
Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Nov 12, 2009 | Bernina Artista 180
Sewing Machines Logo
79 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
