Question about Car Audio & Video
How to reset the audio system in a Tucson City after having to jump start the car
  • brian shevack Mar 14, 2011
    need more details what do you mean reset audio system?
  • 902 Answers
If its not turning on as i need more clarification check the fuse to your sub power cable underneath your hood.
Posted on Mar 14, 2011
2005 hyundia tucson
Search Results
    2005 Hyundai Tucson Recalls - Cars.com
    www.cars.com/recalls/hyundai/tucson/2005/
    Cars.comLook up all NHTSA vehicle safety recalls for your 2005 Hyundai Tucson, and contact a nearby service center for free repairs.
    2005 Hyundai Tucson Problems, Defects & Complaints
    www.carcomplaints.com/Hyundai/Tucson/2005/
    7 days ago - The 2005 Hyundai Tucson has 199 problems & defects reported by ...January 11: Hyundai Genesis Recalled to Replace Dangerous Tires ...
    Hyundai Tucson Recalls ' RepairPal
    repairpal.com > Recalls > Hyundai
    Other systems that may be affected include: cruise control, push-button start, gear shifter, and Electronic Stability Control (ESC) system. Dealers will replace the brake light switch to correct this concern. ... The stop lamp switch may fail, affecting many vehicle systems including ...
    2005 Hyundai Tucson Recall - Learn About Recalls for 2005 ...
    www.automd.com > Recalls and TSBs > Hyundai Recall > Tucson
Jan 28, 2016 | Cars & Trucks
2005 hyundia tucson 2.7 will not crank but lights come on the starter is good
check for a fuse in the starter circuit to the starter motor ( broken ,loose wire)
from your description the power from the start terminal of the ignition switch is not getting to the starter solenoid to energize ti and so start the motor.
Mar 03, 2015 | 2005 Hyundai Tucson
How many kms can the Tucson AWD 2006 2.7L V6 travel on a full tank?
pending type of driving you do . Highway ,city etc it should average around 360 to 380km
Aug 29, 2014 | 2006 Hyundai Tucson
Hyundai audio system in acting weird?
What happened, you forgot to pay your radio bill? Now for the solution. I suspect you tend to turn on the headlights to see in the darkness. That may be the hint that will help find the problem! Try turning on your headlights at the times you say it works and see what happens. If the radio goes off, you have a short somewhere that shorts out the radio power!
Jan 11, 2013 | 2009 Hyundai Tucson
Radio code for 2006 hyundai tucson city
get the radio out, find the swerial number
(is on a sticker on top of the radio)
write the last 4 numbers down
example: 2 5 7 8
ad 1 2 1 2
makes 3 7 8 0
3780 is your radio code.
Nov 04, 2011 | 2006 Hyundai Tucson
How to install a new f/wiper motor to a 2006 Hyundai Tucson City
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc.
Aug 30, 2011 | 2006 Hyundai Tucson
Good day I have tucson 2011 Yesterday I parked my car. Now I'm trying to start the car but won't start, even there the starter motor not working. What is the probliem? I chicked the...
I would start by making sure the battery is good and nithing was left on and drained the battery,check and see if the headlight come on and are bright, if the lights are dim or dont turn on then the battery is low, also check the connections at the battery, make sure they are clean and tight. you can try to jump start it if battery is low. if the battery is good then you may have a bad starter or a problem with the antitheft system,again start with the battery, make sure inside ;ight are working and check the headlights. good day.
May 05, 2011 | 2011 Hyundai Tucson
2007 Hyundai Tuscan, the airbag light keeps coming on. have been to the dealer 9 times in 2 years and they have done nothing but reset it and sent me on my way. how can i reset this myself or have...
A good dealer will never reset it without at least telling you what was wrong and possible solutions. Though a fluke code from a low battery or jump start is possible, usually if there is an srs code it is a real issue. If you have another dealer within a reasonable distance, go to them. There is no easy way to service the srs system for the end user.
Feb 16, 2011 | 2007 Hyundai Tucson Limited
How do you remove a radio from a 2007 Tuscson city
Don't know the 'City' model... but if it's anything like the REGULAR Tucson, remove the shifter knob (remove access place to two phillips screws - remove screws). Remove shifter knob. Pop out shifter cover plate (snaps in and out). Remove approx 6 phillips head screws holding the metal plate above the shifter pedistal. Pop out the cosmetic cover around the radio, AC control panel and vents (wire harness connectors to digital clock, fog lamps and emergency flashers (and pass airbag light). You now have access to the phillips screws securing the audio/radio unit.
Oct 31, 2009 | 2007 Hyundai Tucson Limited
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
