My Tuscany laundry machine has an error message of OE 9i think) but I am not sure what it means?
fixinit4me
  • 10 Answers
SOURCE: error code OE does not finish whole cycle
There has been a recall placed on your model of washer. It applies to ones with a serial number from 10188468GA through 11683946GJ. For mor info go to:
http://www.repairclinic.com/0098_11.asp
Posted on Oct 28, 2007
IB4G2008
  • 3587 Answers
SOURCE: Error Code "OE"
sounds like your machine needs rebalancing..check the feet and floor to ensure it's level and balanced
Posted on Apr 26, 2008
futureloginn
  • 734 Answers
SOURCE: My washing machine
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
for further help go to --
LG
Posted on Nov 14, 2008
SOURCE: tromm washing machine, front load from LG
I am getting an OE message during the washing cycle in my LG Tromm washing machine. What does it mean and how can i fix the problem?
bscavella@sbcglobal.net
Posted on Feb 17, 2009
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Posted on May 18, 2009
What do we when we replaced the pump on a frontload washer, LG, but still get an error message OE?
The DE Code indicates a Drain Error. This means that the washer thinks the water has not drained out of the tub within 10 minutes, which is an eternity for the washer. Since you have indicated that there is no obstruction in the hoses, and filter, and you have replaced the pump, then the only other parts that could be at fault would be the water level sensor, or the main circuit board. Replace in that order.
Aug 16, 2014 | LG Washing Machines
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
While using the machine and during spin operation, the machine dispays the error message OE : drainage trouble, how can i fix this issue
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | LG Washing Machines
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MY LG WASHING MACHINE SHOWS AN ERROR MESSAGE (OE)
Nov 23, 2009 | LG WM1814CW Front Load Washer
Getting the OE error message on LG Tromm
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
I have lost my washing machine manual and i have an error message of OE on my lg direct drive wm166220fd
OE means you have a drain problem. Check to make sure there is nothing in your drain hose. Next check to see if there is anything lodged in the pump.
Nov 16, 2008 | Washing Machines
Error Code "OE"
Apr 25, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
