Question about Samsung Washing Machines
Hu where can i get a new waste pump for my samsung washing machine SAMSUNG SW65ASP2
Got new pump and installed it
Posted on Aug 02, 2008
What is the Aqua Preserve button for? It does nothing when pressed during a wash cycle.
Hi it reduces waste of water by reusing last rinsed out water ...won't function when u select rinsing twice ..cheers
Jul 15, 2017 | Samsung Washing Machines
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Samsung washer wont drain
  • Check drainage pump filter for debris
  • Check drain hose and waste connection for kinks and blockage
Select a spin cycle to drain remaining water. If problem remains, service may be necessary.
Aug 04, 2016 | Samsung Platinum Front Load Washer -...
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
I have a Samsung Washing Machine Intellect SW65ASP2 The error code is E. Filled with water and not draining. I undid a hose at the back and removed a coin which I thought was causing the problem. Any...
you should check the impeller, the thing that looks like a fan, when the coin got in there it would have popped the impeller of the shaft, it does this to avoid burning out the motor. it just pushes on
Jan 29, 2011 | Washing Machines
I have a samsung washer sw65asp2 faulf code 1E
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Samsung SW62ASP Top Load Washer
Samsung SW65ASP2 top load washing machine only lets water in slowly.
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Jan 31, 2010 | Samsung SW62ASP Top Load Washer
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Samsung SW65ASP2
If you are sure there is sufficient water pressure at the hose, then your inlet valve is on the blink....replace it.(the unit where your hose connects onto) Oshie
Jun 22, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
105 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
