Question about Dryers
I have a Roper REX3615EW0. My dryer still runs, but it is not heating. What do you think the problem may be. People have told me that they think it may be the heating element.
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
onthejob5130
  • 640 Answers
SOURCE: dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Posted on Dec 28, 2008
djz83
  • 88 Answers
SOURCE: I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to ....
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Posted on Jan 11, 2009
  • 1122 Answers
SOURCE: blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Posted on Apr 15, 2009
Illeagle
  • 525 Answers
SOURCE: roper dryer won't heat up.
Before you start diagnosing your problem, ascertain that you have made a proper and positive heat selection on the control panel, then proceed.
Below is a link courtesy of www.repairclinic.com, which shows disassembly/diagnostic procedures.
http://www.repairclinic.com/Dryer-Electric-Whirlpool-Style-Version-2-Appliance-Diagram
A volt-ohm meter (VOM) will be helpful in diagnosing most issues.
http://www.ehow.com/how_2076998_use-voltohm-meter-safely.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
Purchase a VOM
http://www.omega.com/ppt/pptsc.asp?ref=HHMA&Nav=vhtj06
Below are the next 4 common failure modes to check.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If all the above checks allright, then proceed to the next steps below.
Thermal overload/cutoff thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%
3d%3di2651&PartID=2651
Cycling thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2893&PartID=2893
Motor Centrifugal Switch.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2584&PartID=2584
Heating Element Connection Wire.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di3140&PartID=3140
Timer.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di548371&PartID=548371
Posted on Sep 21, 2009
I have a Roper Electric dryer that will not heat up and will run through the cycles somtimes. I have ordered and replaced the heating element, thermal fuse, high limit and cycling thermostats. I have
First check the thermal fuse on the back of the filter housing.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-6-539031-/Kenmore-Dryer-doesn-t-heat-11060832990
Attached is a good troubleshooting video. I think that you will find that the Roper is the same as the Whirlpool and Kenmore
Note that the first thing that he does is to test the incoming voltage.
I suggest that you do this with the dryer running. I have seen breakers that will pass voltage without a load and as soon as a load is applied there is no voltage showing. As he says in the video the dryer can run on 110V as the motor is 110V however if it is missing the other leg of the 220V it can't heat. Another way that you could test this is to reverse the two incoming hot wires.
Whirlpool Kenmore Dryer Heater and Thermostat Test
Good Luck.
Sep 19, 2014 | Dryers
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer runs but does not stop, also does heat up.
I have the same problem If you find out let me know someone told me it may be a timer switch. josephr313@aol.com
Aug 20, 2009 | Roper RGX4634KQ Gas Dryer
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Dryer won't dry
hi i think the motor is unstable so the drying ability is decresing check and service it
Sep 10, 2008 | Roper RES7646KQ Electric Dryer
Dryer Heating But Not Drying!!!
if its not heating at all the thermal is the most likely culprit and it was the little plastic piece you seen now if you have a meter set it to continuity and pull one of the wires off the thermal limiter and check it if it reads open its bad same with the heating element let me know now if the heater and thermal limiter are good pull the blower motor vent and check it for blockage
Jan 17, 2008 | Roper REX5635E Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
