Question about HP LaserJet 3050 All-In-One Printer
Hi, whenever i scan a document using my HP 3390 it comes out too faint to read. this is a network printer and seems to work fine for anyone else that uses it. is there anything in my computers setting that i change to fix this?
    Problem Solver:
  • 11 Answers
Does printing from pc comes clear?
if yes clean the scan unit of the fax scanner, if it still does not improve change the scan unit of the fax unit.
Posted on Mar 14, 2011
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
CANON PIXMA MP810 PROBLEMS - Aghhhhh!! I can
Try this,
scan the document to the computer, then view it using a picture viewer.
You may see that the scan is faulty!
The printer may be printing exactly what it sees!
Mar 07, 2010 | Canon PIXMA MP810 All-In-One InkJet...
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
Well its the issue with the printer drivers taking a dynamic ip address.all you need to do is uninstall the printer network drivers,insert the s/w cd that came with the printer and then click on add a device ,it would install the printer drivers all over again.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
May 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Scanner not recognizing software
I also have the same error and same 2015 printer in addition to my 7210.
Anyone figure this out? HP tech level 2 support cant figure it out.
May 23, 2008 | Office Equipment & Supplies
HP LaserJet 3050 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
