Question about Razor E200/E300 Charger
Charger wont light up, batteries wont charge, scooter still turns on but barely moves when the throttle is pulled back. Any suggestions are greatly appreciated
3 Suggested Answers
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
how did you fix the transistor? Can you send me the schematics. dgarbaty at hot mail dot com.
Posted on Apr 09, 2010
Rascal 245. wont work. new batteries. i wired srtraight and motor works. power going to the box under seat but not out
The motor controller may be bad. If the battery charger is connected to the charge port , the scooter won't move even if the charger is not plugged into the wall.
Aug 22, 2016 | Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT...
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Mar 08, 2014 | Razor E300 Scooter
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Pride Sundancer. Batteries will not charge. both batteries test about 50% charge. When I plug charger in to 110v, the needle on rear of unit barely moves. When I turn on key, charge indicator on on dash...
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Jan 16, 2011 | Pride Sundancer 3 Wheel Mid-Size Scooter
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
Razor E200/E300 Charger Logo
74 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
