Question about Toshiba Satellite P305D-S8900 Notebook
Can I connect VGA cable in my Laptop - Toshiba Satellite P305D-S8900 Notebook
    President:
  • Toshiba Master
  • 2,246 Answers
Yes, connect vga cable to vga port
Posted on Mar 14, 2011
    Problem Solver:
  • 19 Answers
Yep u can hook it up to ur monitor using VGA & the port located at the top left side of ur laptop.
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How to connect laptop to vga projector?
you need a cable. it may be the one that usually connects a computer to a monitor = depending what the input is on the projector but it sounds like an ordinary monitor cable as projector is VGA ( the other type has a digital input at one end ;but Im pretty sure thats not it.) If you have another computer set up just borrow the monitor cable and try it. There's already an input for one end in your laptop if its ok buy an extra cable
Mar 18, 2013 | Lenovo S405 14.0inch Laptop
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 16, 2012 | Compaq Computers & Internet
How do i connect my laptop to television using a vga cable
Hey Dude you can connect your laptop using the VGA cable you only need to do is just change the resolution of your laptop to 1024 * 768 and that will fix your issue
Nov 30, 2012 | Dell Inspiron B130, PP21L Series Laptop...
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite P305D-S8900 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
