Question about ASUS Computers & Internet
In my asus m51k series I have problem in internal speaker its produce a distorted sound while if you plug it so headphone or external speakers the is okay.can't you help the solution?
  • 111 Answers
SOURCE: Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Posted on Apr 29, 2008
  • 71 Answers
SOURCE: internal speaker problem
connection frayed
um haard 2 fix if u want i can give u a step by step how 2 fix
just contact me at femi.amoo@gmail.com
Posted on Jul 30, 2008
sleepy_user
  • 140 Answers
SOURCE: internal speakers stay on even after headphones are plugged in
You can open up your machine an physicaly disconnect them.
Posted on Jan 23, 2009
SOURCE: HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Posted on Feb 16, 2009
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
Internal Speaker not working properly suddenly. Hearing Ruptures along the voice.
If you have been using your computer with the audio on full you will probably have blown the speaker cones. An easy fix. Add some external speakers.
May 21, 2013 | Dell Inspiron N5010 Black
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
My hp laptops volume sounds really distorted im not sure why?
The first thing to check is to ensure you have the most updated drivers for your computer and the audio section. If that is okay, then it may be that the speakers are busted. If you have a set of headphones, you can plug them in and if the sound is okay, then the problem is probably your speakers.
Nov 29, 2010 | Computers & Internet
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Why does my I-mac not recognise both internal and external speakers in the sound preferences, so that I can switch between the two without having to unplug the external speakers from the headphone output.
There is an internal switch inside the actual 3.5 mm headphone/speaker jack. When you have either headphones or speakers plugged in, it automatically switches to external. FYI: Macs are also notorious for getting 'stuck' in this mode (external) and I've had to walk numerous people through the steps to correct this. My Macs are definitely not excluded :) I hope this helps.
Jan 08, 2010 | Apple MacBook Pro Laptop Computer with...
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Computers & Internet Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
