Sanyo Dvd player is not responsive to any buttons, "Disc in" and "Play" light are contantly on, and well as the power button which is not responsive and the eject button is not responsive. Cannot remove disc from player.
    Master:
  • 518 Answers
Try unplugging it from the wall for a minute, then see if it works. If not, it's probably a power supply problem inside the unit.
Hope that helps
Geno
Posted on Aug 01, 2008
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Cannot play newer blu ray discs and now cannot play cd's. "This disc can not be played" error message
power off your dvd, disconnect the plug from the power source and then reconnect it again. Power on the unit again and try to resume normal operation. If it cannot still play a dvd much less a cd, then you need to have it repaired. At the most, the flex needs to be replaced or your lens is damaged in which case it needs replacement. Try also locating for a reset button on your unit. Just press the reset button if there is one on your dvd player for about 5 seconds to restore it to its original factory setting
Dec 19, 2010 | Samsung BD-P1600 Blu-ray Disc Player
I record a program, I can play it & see it on the same recorder, but, If I play the DVD on any other DVD Player, an error message says " Improper Disc" or it won't read the DVD. What...
After you finish recording you have to finalize the disc before you can play it in another DVD player.The owners manual will have a section to tell you how to finalize the disc. WARNING!!! Once you have finalized the disc you will no longer be able to record on it. If this helps please rank me and leave a comment. I do not get paid in any way but I like doing this and want to make sure I am helping. I am adding a link where you can download the manual in case you lost it.
http://www.instructionsmanuals.com/modelo-2819-en-DVD+recorders.htm
Dec 18, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
DVD powers up, reads disc, stops, then question mark shows in top right cornor.
The way i fix this, and mine does it quite often, is to either unplug it from the wall outlet and let it stand or a minute or two, or with the unit off, open the tray and close it, and it will recognise the disc then.
Aug 10, 2008 | Cyberhome CH-DVD 300 DVD Player
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
