Question about Saeco Coffee Makers & Espresso Machines
After i cleaned the machine and emptied watertank and put fresh water in it will not pump water through.how will i get the machine to work again?please help
  • 24 Answers
Make sure the machine is plugged in and on. do you have any more information?
Posted on Mar 14, 2011
How do you descale
usually with a white vinegar cycle
Mar 30, 2015 | Saeco Magic Comfort Plus Espresso Machine
How do i descale my tassimo
How are you this lovely night
I assume the descaling prosess is similar from machine to machine
Your pour the descaling liquid/put tablet in the watertank then fill it with water. No coffee in machine. then you empty the coffee tabletcontainer.
Find a jug that takes about a one liter and put the steam spout over the jug.
Your manual tells you how many knobs are to be clicked.before you can start the machine,
Start the machine it will work and rest for an hour. Your jug should be full of water, empty it -watch out it is hot.'
Run itat least once with clean water.
If you have lost your manual you can go online and find MANUALSONLINE.COM.You might well finde yours there.
good luck
Kolbrun
Mar 04, 2012 | Coffee Makers & Espresso Machines
When i discale my Z5 the machine stops after cleaning the caputower and then stays in his programm and doesn't go fearther. What can I do to make the programm go to the end.
Be sure to measure up the correct amount of water before starting up the descaling program. It should be 600ml. Then be aware that the program takes about 45 minutes, and is in two steps. The first 35 minutes is for the 600ml in the watertank. You will then be asked to empty tray, and fill watertank. You can now fill up the watertank with fresh, cold water. Then the machine will complete the program (about 10 minutes) with fresh water, rinsing the system.
So; Be accurate in measuring the correct amount of water (solvent)-600ml
and be patient, this takes about 45 minutes.
Apr 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
We get the message Unit Cal.Fied - what to do?
You need to run the Decalcyfying program. Push and hold the button with the symbol that looks like a tube with small dots inside. You will get the message empty tray and empty grounds. Do so, and put everything back. The message Solvent or Agent in tank will be displayed. Meassure up 700ml water in a container, put 3 Descaling tablets in the water and let it be completly desolved before you pour this into the empty watertank. It`s very important that you don`t use more liquid, this will make the program run forever. When the solvent is in the tank, push the buttoun again, and the program starts. After a while (20 minutes or so) you will be asked to empty tray/grounds again and to fill the watertank. At this point you can fill up the watertank, this will not affect the running of the program. In the end, you must empty tray/grounds again, and after this the machine is heating up and ready to use. Good luck!
Aug 17, 2009 | Jura Capresso Impressa X90 Espresso...
I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Jul 14, 2009 | Jura Capresso Impressa S90 Espresso...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Machine says malfunction and won't froth milk
If you have a rotarywheel; Press and hold to enter the menu, turn to Maintenance, select Decalcify unit; empty tray as requested, fill up 600ml water in a container. Disolve 3 Descaling tablets in the water, and then fill it in the watertank. Press Maintenance button and you`re off.
If you don`t have a Rotary; Turn off the machine and let it cool down for a while, then push the Rinse/Maintenance button for a few seconds; then you will get the message Empty tray. Fill the solution in the watertank and press button.
It`s important that you use the right amount of water, or else the process will "never" finish.
Dec 24, 2008 | Jura Capresso Impressa S9 Coffee...
Watertank empty problem
Couple of things.
Magnet in the water tank could have gone bad in which case you need a new water tank.
2. Sensor for the magnet could have gone bad. Which case you need a new sensor.
3. Flowmeter could be dead in which case it won't feed water to the system, If thats the case its a new flowmeter.
4. Pump. If the pumps not working, it won't feed the flowmeter, which in turn won't feed the system. You'd need a pump in this case.
Its one of the 4. Unfortunately its not an exact science, its a trial by error type thing.
Cheapest way is to send it to a service center. They'll know right away when they open it up. They can also diagnose quicker.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Dec 16, 2007 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
