Question about Nova Development Print Artist Gold 23 Full Version for PC (TGWTNRS)
I want a formula or a procedure to print QUARTER FOLD greeting cards. I only print quarter fold cards and I can not find a way. My 1995 PA still can print quarter fold!! blush@ic-net.com.au
  • blush443 Mar 15, 2011
    I haven'treceived the procedure yet. How can I comment??????
    Master:
  • 525 Answers
How can I print booklets?
One sheet booklets generally are two-sided printing jobs, accordion fold, gate fold or quarter or half fold styles. Determine which of these styles your's will be and make a "dummy"....it's as simple as folding the paper according to its finished form and marking each of the panels with scaled type or pictures. By making the dummy, the layout will reveal itself when opened and flattened. You will most likely have to "flip" the pages and print each side at separate times unless your machine is a "duplex" type of printer. The "dummy" is the key to the puzzle. Simple as folding and unfolding the panels.
Jan 30, 2011 | Canon LASER SHOT LBP-2900 Printer
Prints wrong on windows Vista
That would point to either an incompatability with Vista or incorrect config settings.
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
I am trying to figure out how to print a Half-Fold Greeting Card.
Check the cd that came with the printer, there should be a manual in it.
May 04, 2009 | Computers & Internet
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
I cannot fold greeting cards without getting a margin that is too big on the left side of inside page. This makes it impossible to fold the card and retain alignment.
Discovered that the settings for my new printer were set for LEGAL instead of A4.
Thanks for your interest.
I have noted your e-mail address in case I need assistance in future.
Cheers.
Sep 11, 2008 | HP Computers & Internet
Nova Development Print Artist Gold 23 Full Version for PC (TGWTNRS) Logo
176 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
