Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
I cant pull the cord in my pressure washer it feels like it stuck thiere is no pressure in it it wont pull
    Sergeant:
    Champion:
  • 250 Answers
Take the sparkplug out and see if you can pull the cord then. If fuel comes out of the sparkplug hole the carburetor is leaking gasoline in to the engine filling up the cylinder causing the lockup. The carb has to be rebuilt. Another problem mice like to build nests around the flywheel which will prevent the engine from turning over. You have to remove the recoil housing and if there is a nest clean it out using a screwdriver or use a compressor to blow the mess out.
Posted on Mar 14, 2011
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
I try to pull the rip cord but it just gets stuck and i cant start it how do i fix it
IF YOU HAVE BEEN USING THE PRESSURE WASHER AND THEN TURNED IT OFF,THERE WILL STILL BE PRESSURE IN THE HOSE.YOU WILL NEED TO SQUEEZE THE TRIGGER ON THE GUN WHILE YOU START THE ENGINE.
Dec 07, 2010 | Karcher G3025OH Pressure Washer
The rip cord wont pull to start pulls once and then wont pull real hard to pull
try squeezing the wand when you are starting the motor.
it will let the water pressure go through.
Nov 24, 2010 | Honda Pressure Washer PSI 3000
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Pull cord stuck on my pressure washer.
Need to remove assembly to find problem.
Mar 10, 2010 | Briggs & Stratton Garden
The water will not stop filling up.It never start to wash.
Hi, This will be one of two problems. Either the pressure switch is bad or the valve is stuck open. The way to figure which is: when the tub is filling pull the power cord out. If when pulling the power cord out the water stops it means the pressure switch is bad. The pressure switch can be located inside the control panel. It has 2 wires and a plastic tube sticking into it and is attached to the water level knob. If the water fails to switch off when you pull the power cord this means the valve is stuck open so you should replace the valve. This is located behind the machine and are what the hoses attach to. If you have any other questions please feel free to comment. Mike
Dec 10, 2009 | GE WBSR3140DW Top Load Washer
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
The cord we pull to start the washer machine is stuck
So it's stuck out? If so loosen the recoil assy's bolts and it will snap back once it's loose enough. This usually happen due to bent recoil cover, swelling of the pull rope, or too much pull rope in the recoil (length).
Or it stuck in and won't pull over. If so remove the spark plug and see if it will pull. Keep away from the spark plug oil since if the unit is flooded with fuel or oil it will shoot out of the hole and cover you with it. If it does not pull over without the spark plug in, there is a 90% chance your motor is blown.
Let me know what you find
Mar 30, 2009 | Northstar Pressure Washer Trigger Spray...
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
628 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
