Question about Olympus i:robe IR-300 Digital Camera
I dropped my camera in the pond should i switch it on
  • 24 Answers
NO! you should actually get a big bowl of dry rice and put the camera in there. let it sit at least 24 hours before trying to turn it back on
Posted on Mar 14, 2011
Dsc-wx10 lens stuck in
Throw it away, by the time you have it serviced you will easily pay for a new camera.
Jun 16, 2012 | Sony Cyber-Shot DSC-WX10 Digital Camera
Flotec FPUS1860A utility sink pump won't stop running
Either the float is stuck or the float went bad...
give it a kick and make sure the float has dropped down and is not hung up...
If that don't work then unplug it and replace the float switch...
heatman101
Sep 17, 2010 | Flotec 1/4 Hp Automatic Utility Pump
Change from 230 to 115 volts
Most Flotecs have a switch inside the motor housing that allows you to use either 220 or 110. You'll have to take off the end of the motor housing to where the wires come in to see it. It's usually clearly labeled. Of course, if you are already wired for 220, you'll have to drop one of your hot leads. Good luck!
Mar 12, 2010 | Flotec 1 Hp Deep Well Pump
Transmission oil pressure above 1800 rpm is on
I had the same problem I replaced 2 switches, the first failed because of leaking, the second switch just stayed triggered, with a gauge installed I got 35psi @ 1500 rpm, I really think there is a problem with the new replacement switches, I ran the tractor for about 10 hrs with the gauge installed and it maintained 35-40 psi only dropping with the PTO ingauged or the P/S shifted.
Allis 7000.
Nov 07, 2009 | RTO Allis Chalmers 7000 Tractor Water Pump...
Pump continues to make noise as if its cavitating when there is no water to pump.
If there is no water to pump then it is cavitating. It should turn off when the sump is emptied down and the float drops onto the switch arm
Oct 21, 2009 | RTO Basement Watchdog Sump Pump
Switching off too soon.
you don't need to replace the switch just raise the upper stop up higher so the float can go higher before turning the pump on, it should have a rubber gromet on it slide it up the rail
Jun 21, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
Husband dropped phone into a pond
I would try switching the sim card into another phone. this may provide the transfer bridge you need.
Mar 11, 2009 | Cell Phones
Drop in water
ok I had this happen to me short story simple it was a wedding and one guy was getting out of hand and I ended up in the pond.
ok this might not work but we will see..
gotta dry it out as much as possible do not do anything to it try to turn it on or anything
remove the batteries and any installed cards
find a nice warm spot for it.
use a blow dryer
I let mine dry for a day and nothing let it sit for a week in a really warm spot and it worked.
this might not work for you but if you have pictures on your camera then hopefully it will allow you to remove the pictures from your internal memory.
good luck and keep me posted.
Aug 12, 2008 | Cameras
Olympus i:robe IR-300 Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
