Question about Memorex MVD2016 DVD Player
This is a new system, however, when I first hook up the system up, I got a good clear color picture, but no audio, just buzzing, I changed my wire connection around, and I got the volume and picture, but I lost my color and I have lines running down my screen. (1) have picture (2) no color (3) lines running down my screen (4) menu button will not work any more, can not get access to menu.
  • 902 Answers
I would hook it up via an optical cable for audio or left and right rca cable for audio and try and stick with components for the video should solve the problem. the no color means if you are using a component cable you have put them in wrong. the blue and green look alot alike ihave messed up before. also i did some research on this model. i have heard some people running into these problems no matter how they hooked it up. hdmi the way to go tho.
Posted on Mar 14, 2011
I checked my speakers there not blown out still making buzzing sound. Why?
the buzzing sound is an symptom or indication that there is a defect on the output audio system from your unit. A good audio system does not give out a buzzing sound.
Check for shorted audio wire coming from your audio unit going to the speakers
Feb 23, 2016 | Audio Players & Recorders
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
I have hooked up all the wires to corresponding color. we have a picture, sound. but it is in black and white.
Check the wire connections again.Change the color system of the TV.In order to change the color system use TV remote.Set the color system to Auto
Jun 14, 2011 | Televison & Video
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Aug 09, 2010 | Televison & Video
Constant buzzing even when muted
Hi,It sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00674A you can find it here: http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0?Click=48173 and here's how to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one and go girl power!
Apr 27, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Radio system
Buy a wiring harness for your car at a car stereo shop ($25) then match the colors up -EASY
If you don't have a car stereo shop close by try crutchfield.com
Good Luck
Jun 27, 2009 | Car Audio & Video
Memorex MVD2016 DVD Player Logo
139 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
