Question about DCS FSF-75 Deep Fryer
Thermostat Issue DCS Fryer??
Upon lighting the pilot light and turning the knob to the on position the gas burners automatically ignite. This happens without turning the thermostat control knob to any temp setting.
Please help
River Cat's Fish Fry
  • Anonymous Apr 14, 2009
    I just replaced the thermostat, and no I have this problem. Coincedently, this is why I origianally replaced the thermostat.
  • Anonymous Mar 24, 2014
    It turns on automatic lights then goes off within 30 seconds and tries to restarts but won't. I turn the power off and restart it and it does the same thing again.
    The gas burners fire up but then shut down.
    Champion:
  • 254 Answers
This sounds to me like the thermostat is not sensing and is reading a closed circuit all the time. You will probably need to replace the thermostat.
Thanks
Zerko
Posted on Aug 30, 2008
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
I have a sg14s pitco fryer. Gas valve was bad so i installed new one. Pilot lights fine but when you put gas valve in the on position burners immediatly lights. What is my problem? Thermostat and limit...
Hi there!
When you turn the gas valve knob to "on" position, burners should not fire-up if the thermostat is "off", if it does, the thermostat's mechanical contacts inside may be shorted (will not be able to control temp anymore) and must be replaced with a good one>
Regards.
Nov 10, 2011 | Pitco Frialator Kitchen Appliances -...
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
Fryer lights off, but won't turn off when the thermostat is turned to the off position
The pilot flame will stay lighted even when the thermostat is off, you have to turn the gas valve knob to off position in order to shut the pilot flame.
But when burner flame remains on after shutting off the thermostat, the thermostat's mechanical contacts are shorted or remained engaged. If this is tha case, you have to replace the thermostat.
Jan 21, 2011 | Pitco Frialator SG18S Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
How do you re-light pilot light
Turn the knob on the gas valve to the pilot position. Sometimes you have to slightly depress the knob to turn it..don't use a pair of pliers. In the pilot position.. push the knob in and light the pilot..keeping the knob pushed in for 30 seconds. Let go and the pilot should stay on. Turn the knob to the on position and set the thermostat.
Tom
Aug 02, 2010 | Imperial IFS40 Deep Fryer
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
DCS FSF-75 Deep Fryer Logo
256 people viewed this question
Top DCS Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a DCS Kitchen Appliances - Other Expert? Answer questions, earn points and help others
