I need code for curtis tv and proper direction how to install and retain code
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Hello
Three digit universal remote for Curtis TV are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote code for Curtis are:-
0031 0105 0130
........................... 0004 0009 0000 0049
........................... 0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NB:- Please turn OFF and switch it ON with its front panel power control switch each time before trying an other code. OK.
Posted on Mar 14, 2011
Need the code list for quantum view model QTC32A7F to set remotes
I found a perfect fix for the 32 inch Quantum View TVs with a DirecTV remote.
Press Menu (on your directv remote) , go to settings/help>Settings>RemoteControl>Program Remote>TV.
When prompted to choose a brand, select CURTIS MATHIS. The codes from Curtis Mathis should match the codes for your Quantum View TV.
Note: Make sure the remote can 'see' the receiver during this process.
Sep 09, 2012 | Televison & Video
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
Jan 10, 2011 | Curtis-Mathis CM25011 25" TV
WHAT NUMBER DO I PROGRAM INTO A DIRECT TV REMOTE TO OPERATE A CURTIS TV
Curtis is an off brand set. If there is no code from direct tv then you will have to try the search mode. If that does't work then your out of luck.
Nov 27, 2010 | Televison & Video
Need Direct TV remote code for Curtis LCD2603A TV?
some of these will not work with certain tv's. your direct tv remote should be able to code in your tv with this direct tv or try their website for more answers
Feb 13, 2010 | Televison & Video
I have a new curtis lcd 3717A tv and need the code for the direct tv remote. Can anyone help?
It will be one of these codes. You will need to try them.
00,06,11,15,21,50
Jan 04, 2010 | Curtis CMMT37 37 in. LCD TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
I need curtis tv remote codes for direct tv receiver
Just spoke to Curtis tech support. Most controllers not compatable with Curtis tvs, but there are three codes that will work with some remotes. They are 2622, 2295, 1218.
Hope this helps someone.
Mar 02, 2009 | Televison & Video
I am thinking of purchasing a universal remote to handle my Direct TV, Toshiba TV and Curtis DVD. Is there a code for a universal remote that can be used on the Direct TV? Gary Stroble
You can use the Directv remote to control all those devices.
Curtis DVD code; 21087
Toshiba TV code: 10156 11656 11256 11356 10650 10060 10154 10765 10178.
Dec 18, 2008 | Universal Remote Control DIRECTV Universal...
Codes
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
Feb 21, 2008 | Televison & Video
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
