Question about McCulloch FHH18A Electric Pressure Washer
Plugged in, water is hooked up and on, motor is running but nothing is coming from the sprayer
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
My sink sprayer stopped woking (no water goes to it and nothing is leaking
Debris has come through the water supply and clogged the sprayer, remove debris and test sprayer
Sep 01, 2014 | Niagara Commercial Kitchen Pre-Rinse Sink...
Wash wipe only working on rear window no water comes out of frot. what can i do? 306 1998 model.
If there is no water coming out, and the reservoir is full, then check the plastic lines that run along the bottom most part of the hood (inside of hood near windshield) to ensure the line has not come loose anywhere, has any holes, or has broken.
Also, run the sprayer and hear for the motor running. If it is, then check the resevoir where the motor (should be) and make sure the wiring is not loose there as well. Last, check the sprayers themselves...they may be plugged - if so, if the reservoir is not full, put some hot tap water in it (empty if full, and fill with hot {not boiling} tap water. Then run the motor intermittently (no more than 15 seconds at a time), as you can burn up the motor if run for long periods of time. If they are clogged, this will help clear them out (consider using a dish soap as well such as Dawn (preferred) as it will also help break through the clogged areas.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 29, 2011 | Peugeot 405 Cars & Trucks
I oown a 1999 jeep grand cherokee laredo replaced front windshield wiper pump on resevoir but still no fluid to windshield and i can hear pump.what is my next step.
the hose going from pump to sprayer could be cloged or the sprayer it self is get small wire to unclog sprayer and check hose
Jan 19, 2011 | Jeep Grand Cherokee Cars & Trucks
Heater only works when it's on the highest setting (I believe it's the blower setting). Can't get the windshield wiper sprayer to work. Reservoir is completely full!
Heater: make sure temperature slider is all the way to the red /hot zone. This is a different slider than the one for blower speed. Blower setting will not change the temperature. Sprayer: 1) make sure rubber hose from tank to sprayer is purged (full of water). If unpurged, water wont reach sprayer. 2) make sure that hose did not detach. 3) Can you hear the water pump running when activating the sprayer? maybe cable became unhooked or pump is shot.
Dec 08, 2009 | 2001 Dodge Stratus
Good day I when I start up the unit there is no pressure the motor runs to create pressure, but nothing coming out, after about 20 seconds there is shooting hot water out from the small release black...
The small black valve is a thermal relief valve. It opens when the water gets up to about 145 degrees. If it is heating up that much in 20 seconds, you probably have a bearing issue.
Dec 06, 2009 | Garden
I have a 1998 chrysler concord and i can get windsheild washer fluid to spray the resevoir is full no fluid is leaking out the wipers activate upon initiating the spray sequence but no fluid comes out
Pull out the small tube connected to the jet the fluid comes out of and check for any kind of debris, after blowing out the tube try and activate washer before you connect the hose again if no fluid comes out of the tube than that replace the small pump connected to the resivoir thay are about $15.00
Nov 29, 2009 | 1998 Chrysler Concorde
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen sink only running with the sprayer
It is hard to be certain without knowing the type of faucet, but if you have the type that has a single lever, it could be 2 things I can think of. If you have seperate knobs, I can only think of one. If you have the type with knobs, take the aerator screen off the end of the faucet, The screen may be plugged with saw cuttings of pvc or what ever type of pipe, or even the water saver orifice may be stopped up. If water runs freely with aerator off, you obviously have a problem there.
If you have the lever type, the ball valve can be in backwards, or even a little way off, and the water can not get to the faucet. I am guessing, the whole faucet assembly MAY be in backwards, but that too can usually be fixed by changing the ball around.
Hope this fixes you up!
Dec 21, 2008 | Home
McCulloch FHH18A Electric Pressure Washer Logo
297 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
