Question about Kitchen Ranges
I have an A.O Smith water pump model c48b49c09 that never turn off and i will like an assistance because i dont want the motor to get burn.
3 Suggested Answers
  • 349 Answers
SOURCE: I have a 3/4 Hp Model C48B49C09 3450 A.O. Smith
It should have a tag on pump with information on it concerning hp and gpm.
Posted on May 12, 2010
SOURCE: how to remove motor AO Smith Model C48K2N143CIC
Take off the rear cover as to expose the capacitor. Remove capacitor. Place a 7/16 wrench on the shaft threw the opening where you removed the capacitor. Put a rag on the impeller and with a wrench turn it counterclockwise. It should come off easily. Make sure you replace the seals before reassembling
Posted on Jan 09, 2011
A.O. Smith motor wont spin on its own, just hums. got the motor to spin when it is assisted by hand. so it isnt FROZEN. started up that way too. However had to do so in the final filter basket so I...
If you can, I would certainly replace the capacitor; you are describing classic bad capacitor symptom. There is no guarantee, though, but the cost is low. Remember, the capacitor holds voltage even when the motor is unplugged!
I would bet that once you get the motor running correctly, your pumping problem will resolve itself.
I don't believe that suddenly two problems occurred at once.
Gary
Aug 20, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
My pool pump starts up sounds like its on but not pumping water
Open up the housing between the motor and the strainer basket on the inlet...the impeller, which is the part that actually moves the water is inside. It is likely broken so the motor turns and turns but the pump won't move water. Replace the impeller and the seal if you find this to be true. If you know the brand and model of the pump it will help to find the parts. If not, there may be numbers on the old impeller which may identify it. For assistance, please contact us thru our site at www.arrowpools.net.
John
Apr 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
How to remove motor AO Smith Model C48K2N143CIC
Jun 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
I have a 3/4 Hp Model C48B49C09 3450 A.O. Smith pump and need to know its G.P.M. output.
May 11, 2010 | Plumbing
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Describe your AO Smith 1.5hp Pool Pump Motor 2
According to our Emerson parts dealer, parts for that motor and the motor itself are obsolete. They could not provide a part number to search for or an equal part either. We can quote you a new BN34 if you wish to contact us through www.arrowpools.net.
Aug 20, 2009 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Our A O Smith pump/motor gets airbound everyday
Well somehow air is obviously getting into the pump line. Easiest fix is to move the pump below the water level of the tub and then gravity will keep water in there. If you do have the pump below the water level, then make sure you don't have jets shooting a bunch of air directly at the intake in the tub. If that's not the case and it is below water level, then make sure you don't have a leak in the line somewhere.
Jul 19, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
