Panasonic na 16vx1 washing machine water does not go in and flush the washing powder into the wash
  • 1462 Answers
SOURCE: aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Posted on Mar 21, 2007
  • 14 Answers
SOURCE: Asko Front Load Washer major water overflow from powder dispenser
You may have the hose between the dispenser and bowl blocked
Posted on Feb 15, 2008
blueextc3221
  • 15935 Answers
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 19, 2010
SOURCE: panasonic washing machine model no
it is due to the magnet attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. i got the same problem too but luckily the i found the magnet nearby the washing machine.
Posted on Jan 17, 2011
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
I have a Panasonic NA 140VG3 washing machine that isn't working the code reading is H 43.
a 2011 fixya answer on that code ... its a water leak
and a water sensitive sensor will stop the machine
you may have to contact an authorized Panasonic washing machine repairer
Error code H43 Washing Machines
Oct 11, 2016 | Washing Machines
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
Our Model WM2487H*M detergent box fills with water as the washer is working. We are using Tide pods in the drum.
The detergent dispenser is flushed with water during the wash cycle to remove residue. The flushing occurs automatically regardless of the type of detergent used, liquid, powder, or pods.
Jan 19, 2015 | LG Washing Machines
Why is the Panasonic NA-F70B3 on its very first test wash started rattling really loud and banging on the side of the machine Casing
Any loud rattling sound is bad news. The drum should not be banging on anything!! Return or file a complaint with where you purchased it immediately. Do not wait, there will be a time-limit on returns and after that you are on your own.
Jun 14, 2014 | Washing Machines
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
