Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer not working the heat . only cold blower. what should i do .
  • 552 Answers
Click on the link below it explains how to test all the components that would cause your dryer to not heat.
Whirlpool Dryer Repair Video
http://www.appliancerepairlesson.com/
Posted on Mar 14, 2011
Why is there no heat and no timer operation?
Whirlpool & Kenmore Dryer Repair - How To Diagnose No ...
? 9:01
www.youtube.com/watch?v=JfXBiZOiC2Q
Nov 3, 2011 - Uploaded by canyonman1963 Whirlpool & Kenmore Dryer Repair - How To Diagnose No Heat - High Temp Fuse 279816 OR 279769 Test. canyonman1963.
Aug 19, 2015 | Whirlpool Dryers
Gas Dryer Heat wont stay on.
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
I have a whirlpool dryer, model # LER7646EQ2 drum turns, blower works, but no heat. Pulled out heating element, no coils broken or grounding out, however part of heat sheild is blackened. Before it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Whirlpool Dryers
No heat
Yes it is is a heater element problem. YOu have to access from the back panel. There are screws need to be removed. Once the panel is off, you can see the Blower and the heating element assembly. Take off the housing so you can replace the heater.
May 04, 2010 | Whirlpool WED8500S Electric Dryer
Coils in the back of my whirlp dryer get ht then instantly go out
If the coils get hot then cold it is most likely the problem of the venting. If the heated moist air cannot leave the dryer then the heat will not come back on. You can try removing and cleaning the vent with a vacuum or even a leaf blower ( from the inside of the home to outside )
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool LER7646E dryer is not heating
Mounted on the element is 2 limits. If either is open their will be no heat. NOTE: both need to be replaced and they come in a kit:
Dec 15, 2008 | Whirlpool LER7646E Dryer
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LER4634J Electric Dryer Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
