Question about Canon PIXMA MP600 all-In-One InkJet Printer
Hi! My Canon mp600 suddenly started printing very pale copies, and then (after 3 very pale ones) stopped printing at all--all they paper comes out blank, not a drop or a line! What could that be and how to fix it? Thanks!
  • 1 more comment
  • mmpetrovsky Mar 14, 2011
    there is enough ink in all the cartridges, and there is no message saying the cartridges are low in ink..
    And all the paper comes out absolutely blank!
    I use expensive Canon ink cartridges, and I did replace the ink though there was plenty of ink and it wasn't gelled.
    Also I did try deep cleaning from the screen menu several times, but the paper comes out pristine white and it still doesn't print a thing!
  • mmpetrovsky Mar 15, 2011
    ok, thanks to everyone, but i tried everything with cleaning, deep cleaning to no avail.
    The last update-- now even the LCD screen is not seen at all, though the printer is connected to the power cord. It looks totally dead and unresponsive-- I pressed all buttons, checked the cords, plugged to different sockets...
    President:
  • 3,278 Answers
Hello.
Since you have replaced the ink cartridges, try removing the printheads, swish the tips in a saucer of warm water, blot on a paper towel folded to 4 ply thickness, repeat.
Examine the nozzles, if there is still obvious dry ink left repeat cleaning until ink is gone.
The nozzles are delicate avoid the temptation to scrub them.
Also, try reinstalling the printer driver. Here's how to delete a printer icon in Windows 7:
1. Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
2. Right-click the printer that you want to remove, and then click Delete.
If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, either your USB port on your PC, or the USB printer cable may be faulty.
Hope this helps.
Posted on Mar 15, 2011
  • 844 Answers
Welocme to FixYa!
1. Check if the Ink levels.
For Windows 7
  1. Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  2. Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
For Windows Vista -
  1. Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows XP Home Edition -
  1. Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition -
  1. Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
If the ink levels are low, you need to replace the ink cartridges to resolve the issue.
If not, continue with the procedure below.
2. Clean the print heads.
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Right-click the printer icon and select 'Properties'.
5. Click the Maintenance tab. (The Maintenance window opens.)
6. Load a blank paper in the printers paper tray.
7. Click "Deep Cleaning".
8. Select "All Colors".
9. Click on .
It will start cleaning the print heads.
Note: Cleaning the Print heads uses a lot of Ink.
Try to print again after cleaning the print head.
Thank you for using FixYa and keep me posted.
Jas247
Posted on Mar 14, 2011
  • Jas Barinaga
    Jas Barinaga Mar 15, 2011
    Here's an additional troubleshooting since the LCD and the lights of the printer are also fading.
    Reset the printer to it's factory settings.
    I hope that this will help.
    Keep me posted.
    Jas247
  • 415 Answers
From your description it sounds like it has run out of ink. If it's not out of ink then either the ink gelled or you have dirty print heads. Try cleaning the heads (directions will be in the manual)...
Cheap replacement ink can gel up and quit working even though you haven't used the whole cartridge. That makes them not so cheap after all. Better to buy good ink.
  • 639 Answers
The catridge is empty, load with more refill ink
Printing blank page
Open the top and make sure the carrier is not stuck to one side and also check that the drive belt is on.
Jan 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
When trying to print, paper gets jammed, screen comes up with 'error code 6A00'
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon Pixma MP600 printer has an error coming up of 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jan 29, 2010 | Canon Pixma MP600 Printer
Have the canon mp600 and like others it has the 6A00 error that won't go away. It had a paper jam and paper was pulled out- can't see if a fragment is left. May try the shaking technique- other solutions?...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
CANON MP600 - NOT PRINTING IN BLACK INK
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Apr 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Locked In Copy Mode--Error Message: 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Sep 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
