Question about Vizio P50HDTV20A 50 in. Plasma HDTV
I have a fuse problem it went out after 2 years and put a new 1 in it lasted 5 mo. anouther new 1 it lasted three weeks. Can i put in a stronger fuse?
    Problem Solver:
  • 10 Answers
If a fuse is blowing, it's usually caused by a short somewhere and is intended to prevent further damage or a potential electrical fire. It's generally safe to use a fuse rated for ~10% more current, but if it still blows out, I'd recommend taking it in for service. A higher rated fuse will have no bearing on the normal operation of the TV.
Posted on Mar 14, 2011
My 1995 gmc 1500 ext cab siarra 's ac stopped cooling, i put at least 2 1/5 cans in it about three weeks ago, it was running fine until a day ago, please tell me what is wrong, is it compreesor re
You have a leak,to see if you do,get a spray bottle,put soap water in it and spray all a.c.lines and see if it bubbles up any where.Look for usual stains at connections.
May 25, 2013 | 1995 GMC Sierra C1500
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
I have a 2008 Suzuki Boulevard C90. The battery is about 1 year old, I ride most of the year around and put it on a 1 amp battery charger about every two weeks whether need to or not. Went to start this...
I think you need a battery it is not holding a charge Also take voltmeter when you jump it When running put voltmeter on battery and see how many volts is charging while running It shoud be 13,50 GOOD LUCK MOPAR KENNY
May 22, 2011 | Suzuki Boulevard C90 Motorcycles
Bought a new 2006 Armada in Aug 2006. Transmission went out & was replaced in 2008 or 2009 w/ a new transmission. Transmission went out again last week (Feb 2011). Nissan dealer is saying it's out...
forget the dealer...contact nissan directly and youll probably get more favorable results.1800nissan1.btw if vehicle has less than 60k your still covered by your powertrain warranty.
Feb 15, 2011 | 2006 Nissan Armada
Have a Crate V50-112.Have had it for 1 year. Replaced tubes 2 weeks ago, turned amp on tonight, started to play, amp went dead. Checked fuses, they're good. Any ideas?
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Feb 02, 2010 | Crate Music
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Car is not wanting to accelerate
Did you check the catylactic convert may be plugged
Dec 03, 2008 | 2001 Chevrolet Corvette
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
314 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
