Question about Garmin Nuvi 465T Car GPS Receiver
At first i tryed updateing it and i used the wrong update .so i did a master reset. that dint work. the web updater would nor recanize the garmin 465T . so i used google to get the right updat then i got the update . then u open the garmin and deleted the curuped file the i . unziped the update and plced the updated file to the garmin. it started working. it lasted for 3 hr. the the batery got low . it shut of and i recharged it . it came back on and said system software is missing.
    Sergeant:
  • 166 Answers
Find a local Garmin dealer - there's no way to reinstall system software once its missing essential parts to complete a startup.
Garmin allows updates in battery mode which can brick the GPS once it runs out of power during the update.
Posted on Jun 26, 2011
My garmin nuvi 610 stop locating GPS
Have you tried resetting the nuvi 610? There is a reset button under the antenna, press it and hook it back up to the power source. this should work.
See page 4 of the manual for photo and if this does not work you can try clearing the unit also on page 4..
Also have you updated you Garmin at the Garmin web site? There is usually software updates that will help it recognize the new satellites.
I have attached a link to the owners manual below.
http://www8.garmin.com/manuals/1262_OwnersManual.pdf
Here is the update link:
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Thanks for using FixYa, and please let me know what solution worked.
Jun 11, 2011 | GPS
My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
May 03, 2010 | Garmin nuvi 1350 Car GPS Receiver
Get frozen old the time my gps garmin 660
if its frozen to the point that it will not turn off, lift the external antenna and push the reset button, then start it up again and see if its ok. if not
make sure its has a good charge,plug it in to the usb port2.gif on your computer for a few hours.
if that fails, try a reset
note: the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
hook up the nuvi to the web updater and get the latest update
you can get the Web Updater HERE
bill
Nov 06, 2009 | Garmin Nuvi 660 GPS Receiver
My garmin begins to load and them goes blank
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Sep 27, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin nuvi 650 will not go to next screen it
have you tried the master reset?
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
bill
Sep 27, 2009 | Garmin nuvi 650 GPS Receiver
My garmin sometimes gets lost ,do i need to update ?
yes,a update will probably fix that problem. hook it to the web updater from garmin. that will detect what updates you need automatically. youll need your usb cable to connect to your computer.
if you do not have the web updater, it can be downloaded HERE
bill
Sep 20, 2009 | Garmin nuvi 205 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Black screen displaying only Garmin and a blue triangle
to soft reset & keep data....
Slide power key to on/off, hold it for 8/10 seconds
Update from Garmin, use the web-updater. keep it updated, delete old junk and POIs.
hard reset.
Hold lower corner of screen, while turning on, keep pressing, when "clear all data appears" click yes,
sould resolve the problem
Hope this helps.
Regards.
Feb 09, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Streetpilot 2620 Goes not go to maps
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
Aug 25, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Nuvi 465T Car GPS Receiver Logo
275 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
