Question about Ovens
I think my Delonghi oven AOV 842 bulb fused, and it caused the electricity of my house to trip. How do I change the bulb? There seems to be a panel covering it and I can't get to the bulb.
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Posted on Jan 06, 2009
  • 4 Answers
SOURCE: Can't remove the oven light cover to change the bulb
clean it with wd40
Posted on Jun 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: Bottom oven on Electrolux EOU 6330
Probably a broken bake element.
Posted on Jul 05, 2009
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
Electric trips off when oven reaches temperature
this can be caused with anything that heats up ( irons etc ) as they overload the fuse when heating elements are worn or have a bad earth wire which has weakened over time. is it a second hand cooker ? or old house ? its down to power through the wire causing the fuse to trip
Apr 23, 2015 | Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
My Delonghi EST461 ST oven has stopped working. The grill and fan work but the oven does not, it initially tripped the fuse. Any suggestions
always turn the power off first , you will need a flash light look carefully around the bottom element , I think it has burned out on you , it will have a bump or burned spot on it or may even be broken off , this is bery easy to replace and cheep if you find it is burned or broken off email all info on oven make, model, serial number I will locate the part and tell you how to replace it Have a nice day !
Dec 06, 2011 | Ovens
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
DeLonghi EOF260 tripping the circuit breaker
It is probably an element that is causing the trouble, as it gets hotter, the insulation resistance breaks down, and if there is a weak spot or hot spot it causes the trip to operate.
I'm afraid it is a question of elmination, trying different functions, until you isolate the problem.
Feb 09, 2010 | DeLonghi Ovens
Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Jan 03, 2010 | Neff U1721 Double circotherm Electric Oven
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Ovens Logo
67 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
