Question about GPS
The wires touched the ground and the remote wire touched i smelled a little smoke and then the lights stop working
  • 902 Answers
There is a built in fuse on both the adapter and inside the gps device check to see if the fuses are blown
Posted on Mar 14, 2011
If battery wires grounded out by touching each other would that make car not turnover all lights work where do I check relays an grounds
if the battery wires touched each other with out going through the battery --nothing would happen( just 2 dead wires)
if a positive wire end touched an ground wire while the terminal was connected to the battery, there would have been a flash and sparks but little else
if the two battery posts or terminals were connected with leads connected then there would be a flash and sparks and the possibility of an exploding battery
Oct 15, 2015 | Cars & Trucks
My 02 saturn sw stalled out going down the road, wont restart. towed back to the house. smelled burnt wires when i lifted the hood. tried to crank, single click noise, oil light and emerg. light on, and...
Okay--I am thinking about several things here. Electrical fire; engine failure; coolant system leak. Visual inspection--look at the wires on the engine, do they appear melted or are any of the wire casings soft? Check the fluids for the engine (e.g.-oil coolant) if you have water in your oil or coolant is black you could have blown a head gasket. There are some hoses on the firewall side that go into the block or intake manifold, check them for tears, cracks, etc. After you have diagnosed the problem a little more--re-post.
Nov 09, 2013 | 1999 Saturn SL
TO-30 quit running, puff of smoke from electrical? Won't turn over
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
Apr 16, 2017 | RTO Massey-Ferguson Tractor TE20, TO20,...
Have electrical issues with 1996 T&C van. Problem with Remote Starter and smoke and smell of burning rubber. Had to disconnect battery to get the van to stop trying to start. When i drove it home, it...
Yes it is . The remote starter wire has touch together and is wanting to start the starter, they have shorted together, The burning rubber smell is the wire melting due to the electrical short. Take the remote starter out plus the push button and reinstall using new set of wire And if you decide to install a new remote starter youll have to install a fuse in line with the positive wire.
Apr 24, 2011 | 1996 Chrysler Town & Country
1991 S-10 Chev Blazer Sport: All dash lights went out but fuse is good. The speeddometer would come and go then for months it worked, then today the whole dashlights went black. A short?
A short circuit is when any positive wiring touches any metal or bare wire that is grounded (to Neg Battery terminal). this would normally blow a fuse, and might burn some wires and give a burning pungent smell and maybe a little white smoke A Broken/OPEN circuit is when a wire is disconnected, wire broke or corroded so the wire doesn't make good contact. The instrumental panel is supposed to be grounded to the body/ Neg terminal on battery. a corroded ground wire could cause this. electricity has to complete a full circuit any disruption (fuses in Pos Wiring or any break of circuit in neg side wiring, did you ohm check fuse or a contuinity check, some times a bad fuse looks good to the eye . the dimmer switch could be bad, it's a cheap easy fix. do you or any previous owner live near the ocean, salt water causes a lot of corrosion problems in ground connections and dimmer switches . verify fuse good again as described , because you described a intermittent problem its probably the dimmer because a blown fuse can't repair it'self, but a corroded or wornout DIMMER SWITCH WILL MOST DEFINATELY, INTERMITTENTLY make a good connection causing the lights to work or fail spazmotically, so it is the most likely culprit.
Feb 07, 2011 | 1989 Chevrolet S-10 Blazer
Installed lanzar 266 amp yesterday it went in protect mode on a song and now everytime i turn it on it is in protect mode
most commonly that means that somewhere there was an arc in the electrical either the pos or neg going into the amp or rcas or its the speaker wire from the amp to to the sub itself look especially for little wires touching opposit polarity wire (like a little +wire has moved and touched a - wire)
Oct 07, 2010 | Lanzar VIBE266 Car Audio Amplifier
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Flashing dash lights
if it runs ok leave well alone the smell will linger for long long time though ,open a window
Jul 22, 2008 | 1995 Isuzu Trooper
My amp was smoking and I want to know how to repair it.
The Amplifiers Positive to ground will only hurt the wire to the battery, and blow the main fuse near the battery.  Check the main fuse near the battery.
Oct 28, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
GPS Logo
16 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
