Question about Fagor LFA-073 IT Dishwasher
I have s fagor dishwasher model IVF 561AL. Ive been using for the past 6 years. The problem now is there in hot water comin and i had the technician came and got the hearter and timer replaced. Still i'm facing the same problem . Its been weeks and the technicians are still working on it and the the machine is in the warehouse still. Plase let me know what's the real problem.
Fagor dishwasher is showing F2 please help.
Not drained in time allowed (6 minutes) - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Aug 12, 2016 | Fagor Dishwashers
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
Sir, I have a Kenmore Dishwasher, model 363.14455690. The dishes when dry still come out slightly wet; most everything still has to be wiped dry. Can I increase the heat some how??
it is a comination of fully fully rinse agent compartment and hot water. the rinse agent helps with the drying and the steam from the hot water is the finisher . check that first .i this helps you then help me by sending me a 4 thumbs up post. thanks!
Feb 22, 2010 | Kenmore Dishwashers
Why do dishwashers have SO much longer run times today than those of the past? Our new Kenmore ''Ultr-Wash'' has extremely long run-times. How can that possibly be a good thing in terms of saving energy?
The latest models all pride themselves in doing a perfect job, almost silently, using much less water than the older models [thus the energy savings] as the most costly part of a dishwasher wash used to be the cost of the hot water. Your dishwasher only uses about 2 KwH of electricity compared to ten year old models that use 16.
Jan 30, 2010 | Dishwashers
Not good washing
You are either not using enough of the wash chemical or you need a product like Jet Dri...what you are seeing is mineral deposits.  Make sure your water temperature is hot enough.  If not sure, use the cycle which heats the water.
Nov 15, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Fagor LFA-073 IT Dishwasher Logo
66 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
matt
matt
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
