Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a 15hp johnson i can motor along slowly but when i go to open it up to full throttle it goes out of gear then when i take the throttle back down it will jump back in again
  • 48 Answers
Sounds like a bearing gone in the drive shaft or a worn gear
Posted on Mar 28, 2011
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
How many turns of low idle screw for 1986 johnson 30 hp, ELCDM
Start with one. Bring the speed down slowly. If the motor "sneezes" and dies ,open more, maybe one-half turn and restart. If engine now runs as you idle down, slowly turn in the idle screw until the motor starts to speed up without moving the throttle. A little more and it should sneeze again. From the point where it started to speed up, back the adjustment about one eighth to one quarter turn open. See how it runs. If you have to open the idle screw way out or it keeps sneezing you probably need to clean the carb.
Aug 23, 2014 | Boating
Does my 1979 johnson outboard charge the battery thru the powerpack?
Some models charged through a Magneto, but see if you can find the 1979 Year Manual. I have a 1979 engine myself in a 15Hp which is a Manual start(no battery) and I have a Sailhorse Johnson 8HP which has an electric port and is Manual start. I believe the 8HP would charge a battery as on a Sailboat the running lights needed power. The 8HP could power the lights directly.
Johnson offered options for electric start in lower HP units and options in charging systems to contain costs. You might get a better answer from someone by listing the HP of your motor. I was the original owner of the 15HP and remember the 9.9HP and others in the same Sales brochure. The Sales brochure may advertise more about the charging systems.
Jul 21, 2014 | Light Outboard Motor Boat Bass Fishing...
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
Need owners manual for 1956 Johnson Seahorse 15hp
In order to solve the problem I needed to completly break down and diagram the entire motor. Not easy, but it worked. I started with the fuel system and made my way through till I had the motor broke all the way down to the pistons, and rebuilt it after making a diagram of every working and cast part. This included makeing note of part numbers and along with size, shape, and where the parts fit in aspect to the entire motor. In order to do any of this yourself mechanicale dtrafting paper will be needed and a lot of time.
Sep 09, 2009 | Sport & Outdoor - Others
Motor was running great, but it died slowly and never start again
check to see if you have a spark -then check if you are still getting fuel-and how old is the fuel-because it is recommended ,an im assuming its a 2 stroke motor,that the fuel should be replace with a fresh 2 stroke mixture every couple of months as the mixture jellyfies and sludges up the carb etc-try those first
Jul 06, 2009 | Sport & Outdoor - Others
2002 15hp mercurty 2 stroke long shaft need 2 know installation specs 4 propeller depth from top of transom model # 1015211zd
I have a 1979 Johnson 15hp Long shaft, and as a single motor just followed the rule of a shortshaft motor for a short transom and a longshaft for a deep transom. You have a little adjustment in the mount clamp. You want enough shaft not to cavitate and want the trim fin below the hull. If this is a kicker motor you want it deep enough for water pickup but less deep for drag on fixed mount.
May 11, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
187 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Are you a Light Boating Expert? Answer questions, earn points and help others
