Question about AT&T 650530003417 Cordless Phone
I have a AT&T model # EL 42308 with 3 stations. I get a continuous dial tone when calling any number. I press phone...get a dial tone...then I have a dial tone after each number pressed. Of course the call will not go through. I have tried unplugging and plugging back in...clearing all messages...waiting for phone to recharge. I am at a loss????
  • badkins8 Mar 14, 2011
    That fixed it!!! Thank you very much, Will
    That fixed the problem! Thank you very much...
    Genius:
  • 1,196 Answers
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Posted on Mar 14, 2011
Why will my uniden phones not dial out, all units will not dial out. Phone jack works, but when I try to dial, with each digit pressed I only get a dial tone. Phone will receive calls, but I cannot dial...
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires.
This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular socket you are plugging
the base ('main unit') into.
Feb 18, 2015 | Uniden Cordless Phone
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
AT&T 650530003417 Cordless Phone Logo
674 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
