Question about Altec Lansing ADA 890 Computer Speakers
The speakers made a repetitive popping and buzzing sound that seemed to strobe as soon as I plugged the entire system in. After awhile the popping stopped and the speakers began to play music, the display on the speakers works fine, but the speaker that has the display will not play at all. These speakers have worked fine before but now only one plays. I'm wondering what might be the problem because everything is plugged in and I know that the speaker that isn't playing isn't blown.
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 14, 2011
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Your model has all the audio and video circuits that are all within the Control Box unit which has to be replaced as a unit. You can get one at the following link. You would have to leave them a email as they dont list the polaroid Control boxes, But I know they have one for your model. Just click on the " contact Us" link and let them know the model number they respond quickly.
http://servicemanuals.vstore.ca/
May 05, 2009 | Televison & Video
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Speaker popping when computer is on or off.
I use to get that same sound but only when I first booted up.
Is this only happening when you have the volume up and does it happen if you turn down the sound all the WAY not off
Your MIC could be enable and on boost level.
If you sound is popping from the music or other source is it from all the speakers???
I can try and help
Aug 28, 2008 | Altec Lansing AVS 500 Computer Speakers
Webcam Speakers Echo and Double Feedback
"Noise", as used in this document, is a general term referring to any sound a speaker system makes that is not part of the original source material. There are many different types and sources of noise, each with its own solution. Below is an explanation of the common types of noise, what causes them, and how to minimize their occurrence.
Hum or Buzz
There are four common causes of humming and buzzing:
  1. Sound card If the humming or buzzing gets louder or softer with changes in the volume setting, this is an indication of noise coming from the sound card. In this case, check all of the connections to the sound card to make sure they are all completely plugged in and secure. Then, adjust the level setting of the sound mixer to obtain the best performance. Generally, you should leave your CD volume settings in the mixer at full and reduce the sound card's master output level down. For information on doing this, please refer to your sound card manufacturer's documentation.
  2. Unused input cables If you are not using all of the source inputs to your speaker system (such as using a 5.1 speaker system with a 4 channel sound card), the unused input cables will pick up noise. The solution is different for each speaker system, as described below:
    Z-540 / Z-560 (2 channel sound card): Depress the M3D button.
    Z-640 (4 channel sound card): Depress the Matrix button.
    Z-680 (2 or 4 channel sound card): Disconnect the unused input cables from the control pod
  3. High-power devices If you are using other high powered devices on the same electrical circuit, they may be causing hum or buzz. If so, discontinue their use while you are using your speaker system. Examples of such devices include microwave ovens, halogen lamps, power tools, etc. Also note that high-power devices with dimmer switches (such as halogen torchiere lamps) will cause an especially pronounced buzzing effect. To minimize hum or buzz, make sure that the dimmer switch on these products is either all the way on or off.
  4. Electric Polarity In many countries, the US being one, the electrical power grid is polarized. In these countries, the power plugs are designed so they can only be inserted into the wall socket in a single direction. For example, in the US one of the plug blades is larger than the other. To avoid humming and buzzing, both your computer and speaker system must be properly plugged into polarized outlets. If your wall outlets do not have polarized plugs, as in the case of many older homes, and you are using adapters to plug these power cords into the wall, it is possible that the polarity of either your computer or your speaker system is reversed. In many other countries, such as most of the European continent, wall sockets are not polarized at all - making it even more difficult to properly match the computer and speaker system. To solve the problem you will need to remove the power plug from the wall outlet, rotate the plug 180°, and re-insert it into the wall. Try this for your speaker system power cord, your computer power cord, or both. You should be able to find a combination that will eliminate the humming and buzzing.
Pops and Clicks
There are three main causes of pops and clicks:
  1. Sound Card Many pops and clicks are created by the sound card. There are two common causes: sound card quality and older or mismatched drivers. If the overall volume level of the pops and clicks goes up and down as you change the volume on the speaker system, the noise is being generated by your sound card. Lower quality sound cards don't include the necessary circuitry to cleanly remove noise from the sound output. Logitech's higher-powered systems, such as the Z-560 and Z-680, are also sensitive to the overall quality level of the sound card. If you are using an older or lower quality sound card, we suggest upgrading your sound card. The other primary cause is older or mismatched drivers. Make sure you are using the latest drivers for your sound card.
  2. Multi-tasking If you are running more than one program on your computer that accesses the sound system at the same time, small pops and clicks can be common. This is a function of your computer and/or sound card. A common example is using a program that generates occasional audio feedback (such as beeps or other sound effects) while listening to an MP3 track in the background. The solution is to turn off audio feedback in the first application so that the background MP3 track is uninterrupted.
  3. Interrupts in the Digital Bitstream On digital systems, such as the Z-680, it is normal to hear a very faint "tick" when you switch between inputs (by pressing the input button). You may also hear louder 'clicks' or 'pops' on a device such as a standalone DVD player or a sound card if it is plugged into one of the digital inputs. On some systems, this noise may occur when skipping tracks, switching audio streams (for example, from Dolby Digital to DTS), or navigating a DVD menu. The clicks and pops occur because the device is sending out an interrupted digital data stream. This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. The Z-680 has been extensively tested with the latest sound cards, software DVD players, and standalone DVD and CD players. If you experience extensive popping and clicking, we suggest upgrading to the latest version of your software DVD player or, if using a stand alone device, trying a different speaker model. If you need more assistance with this issue, please contact Customer Support.
Stutter
A stuttering sound track is an indication of either insufficient or conflicting computer resources. Check to make sure that your computer has sufficient processor power and memory to handle the applications you are running, especially if you are using a software DVD player. Defragmenting your hard drive may also help. If you are sure you have sufficient resources, check to make sure that you don't have any conflicting IRQ or DMA channels.
We have also seen some software DVD player/sound card combinations that cannot properly output a Dolby Digital or DTS signal through the sound card's S/PDIF digital connector. (S/PDIF is a generic term for either coax or optical digital connections.) The result, when using a Z-680 hooked up to a S/PDIF connector, is a stuttering soundtrack. As mentioned, this stuttering is caused by the computer, not the Z-680 speakers. Switching the software DVD player's sound output to the 5.1 analog outputs will generally solve this problem.
Hiss
All high-powered amplification devices - everything from multimedia systems to home theater systems to movie theater sound systems -- generate some level of background noise, or hiss. In addition, low quality sound cards with poor signal-to-noise ratios can generate a significant amount of steady hiss that is reproduced on the speakers. Under normal conditions at a normal listening distance, the hiss coming from the sound system should not be noticeable. In a very quiet room, or if you place your ear very close to the speaker, you may hear a very low level hiss. This is normal, but should be completely masked by normal music and game sounds.
If you find that hiss is noticeable, it is likely that the speakers are too close to your listening position. If the speakers are too close, you will not obtain the best imaging of the sound and you risk damage to your hearing when the system is playing at full power levels. Try moving the speakers further away from your normal listening position. We recommend at least 18" for the moderately-powered systems (such as Z-340, Z-540, and Z-640) and at least 30" for higher-powered systems (such as the Z-560 and Z-680).
Also, note that the satellites in most Logitech speaker products are designed to be wall-mounted. Wall mounting the speakers provides two benefits: 1) it moves the of the satellites further away from your listening position, making any hiss less noticeable and 2) it moves all of the satellites further away from each other, providing better channel separation and surround sound spatialization.
Feb 16, 2008 | Logitech Webcam
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Altec Lansing ADA 890 Computer Speakers Logo
187 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
