Question about Savin Office Equipment & Supplies
I have a savin color copier model c2410 that as Sc421 code. And I replaced the high voltage power supply board and the harness that goes to rear wall with rear corona block. It Work one day and the SC421 code reappear. Any thoughts about this problem?
  • 5,370 Answers
Try clearing the code by entering the service mode.------ Codes that begin with "SC" refer to issues with the fuser area. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified technician.
Press the "Clear Modes" button. This button will be on the main panel of the copier.
Press the "1,0,7" keys in succession. You do not have to hold the buttons down at the same time but need to press and release them in this exact order.
Press and hold the "Stop" key. You will need to hold this button down until the copier enters into service mode. The touch screen display will read "service mode" and three soft keys will appear.
Press the "exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
Turn off the main power. The main power button will be located on the side or front of the copier.
Turn the power back on. Once the copier is powered back up, the service code will be cleared .Try this .Check out.Keep updated.Thanks.Helpmech.
Posted on Mar 14, 2011
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
191errorcode
Dear Simi,
Please try the below solutions
Solution 1:
The wiring between the DC controller and the high-voltage power supply was broken. Replace the high voltage connect cable.
Solution 2:
Check for a pinched wire in the harness from Connector J404 of the High Voltage Power Supply PCB to the rear frame connector of the ImageRunner, J4001. It may be necessary to replace the High Voltage Power Supply.
Regards,
Samy
Aug 10, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
3115cn power supply
"Low Voltage Power Supply" in a laser printer usually means the AC to DC power supply in from your wall outlet. The "High Voltage Power Supply" is often in the center of the printer and provides the high power required for imaging internally.
Mar 03, 2013 | Dell 3110cn 3115cn and 5110cn Color
Why is it displaying sc300 error?
High voltage power output error The measured voltage is not correct when the EGB measures each charge output (charge, development, image transfer belt unit, and transfer unit).
  • Disconnected or defective high voltage harness
  • Defective high voltage power supply
  • Defective EGB
  1. Check or replace the harnesses.
  2. Replace the high voltage power supply board
  3. Replace the EGB.
Jan 30, 2013 | Ricoh SPC242SF Colour Multifunction...
What is a 350 code on a savin 8045 copier
This code can be reset be turning off the main power (orange rocker switch) for about 10-seconds and then turning the machine back on. If the error comes back up, then there is a definite problem with the machine and it should be looked at by a train service technician.
SC350:
ID sensor pattern test error
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Causes:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
Apr 01, 2011 | Office Equipment & Supplies
Savin copier c2410 error code 421?
http://www.restoreguard.com/p/error-421.html?keyword=Error%20code%20421&gclid=CNTmo4vZ26UCFYtspAod1CIj0w
very common fault with win 7 click the above link and it will install the corrupt / missing program files
Dec 08, 2010 | Savin Office Equipment & Supplies
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
46" projection not coming on
You have an power supply problem & or a high voltage flyback transformer gone bad. The regulator is usually an STK followed by some numbers, located on a separate small board above the main chassis in the rear of the tv. The flyback is down on the main chassis & has a red high voltage lead wire coming out of it that goes to the high voltage/focus block.
Aug 07, 2007 | RCA P46924 46" Rear Projection Television
41 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
