Question about ASUS M2N68-AM SE2 Motherboard
Hi. I get a blue screen with bad_pool_caller error, xp pro starts and stops and then blue screen and reboot forever. Is the motherboard (ASUS M2N68-AM SE2) in default. AMD PHENOM QUAD CORE CPU temperature is 37Celsius, according to specs looks ok. Is there an answer other than change the MBoard. Thanks
  • 64 Answers
Dear mariolama
It can be due to error in any newly installed hardware or software.
Most probably due to RAM. Check your RAM is perfect or not in other system. Or clean it and restart the system and check.
Reply me the status
Thank you for using FIXYA
Posted on Mar 14, 2011
ASUS M4N68TM 1TB hitachi HDS721010C SATA Drive 460gb partition Phenom II X2 Trying to load Windows XP Pro For a client of mine. Windows trys to install but after the format partition part it reboots then...
What Service pack of Windows XP are you using? A 1TB drive will require SP2 or 3. Also, does this board require "AHCI" drivers (hitting F6) to install special boot time driver.
It sounds like a boot time driver. The other option is that there are bad blocks on the drive. That will do the same thing. However, check into boot time drivers, Visit http://support.asus.com look up this motherboard and see if there is a "SATA driver" required .
Jan 07, 2011 | ASUS M4N68TM Motherboard
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Compal fl92 notebook will not POST. DVD/cd rom works, lights come on power button and hdd starts, cpu fan spins then nothing happens from there. before this i had checksum errors,memory management...
well try to remove the RAM from its sockets and clean up the contact area of the RAM using eraser and repalace it and try to reboot it.
Good Luck.
Jan 07, 2010 | Computers & Internet
Asus p5q pro with intel quad core 9550 end so win 7 64 bits i have a lot o blue screen
Blue screens are usually hareware errors...but can aslo be caused by software issues so if you have installed anything new even like your windows 7 or any other new programs..make sure you have the windows compatible to your motherboard....and if your motherboard supports your 64bit system on windows 7 just make sure you have the right drivers installed for it..check that you have no viruses ect.. aso make sure your memory is supported and maybe clean them out by blowing out dust ect...let me know what happens so i can try help more pls ...
Jan 05, 2010 | ASUS P5QL PRO Motherboard
Get blue screen when trying to install windows xp on an asus p2b motherboard I keep getting error code 7 and it stops install process
hi this is problem of operating system or RAM not motherboard.
you have install os again & check your system RAM
Nov 18, 2009 | ASUS Intel 440BX Chipset P2B Motherboard
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
I cannot reinstall windows xp in eeepc asus701
check the HDD for erorrs.
In which step you r getting BSOD, in text mode setup or
setup after reboot (GUI MODE)
Apr 13, 2009 | ASUS Eee PC 701 Notebook
Sound card
Your motherboard has 6 CHANNEL ONBOARD AUDIO - Experience high-quality 6-channel 3D surround audio with the optional C-Media CMI8738 audio controller. The driver can be downloaded here...
http://support.asus.com/download/download_item.aspx?model=A7S333&product=1&type=All&SLanguage=en-gb
hope this helps.
Apr 08, 2009 | ASUS A7S333 Motherboard
Cannot install windows xp
sounds like a bad usb device or memory. try eliminating unnecessary things.
Nov 07, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
ASUS M2N68-AM SE2 Motherboard Logo
119 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
