Question about Welding Tools
Need to know function of switches and knobs on control panel. New to tig welding and bought the machine used but without a manual.
  • 407 Answers
Hi:
Give your machine's brand and model number and I will help you.
Regards,
Posted on Mar 14, 2011
What settings do i use to arc weld.
Not sure what machine you have, but it should be DC straight (electrode negative or DCEN) and DC reverse (electrode positive or DCEP). The polarities have different characteristics. For example, if you're planning to TIG weld, you would either use DCEN or AC (if welding aluminum). For the general stick welding process, DCEP tends to give you a deeper weld. The welding rod you buy will have recommended machine polarity and amperage range settings, you should use the recommended polarity for whichever rod you're using because different rods are designed to weld under different circumstances. But, generally speaking, most welding rods for steel will work on DCEP without much trouble.
May 17, 2016 | ARC Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
What is the basic technique in welding
Hi:
Well don't know were to start, basic technique goes according with the type of metal to weld and type of wire to use.
I think if will be better if you read the basics of welding with MIG machines with an owner's manual. Check the link and go to section B-7.
http://www.lincolnelectric.com/assets/servicenavigator-public/lincoln3/im564.pdf
Sep 13, 2011 | Welding Tools
Lincoln precision tig 225. Makes bad aluminum welds in AC. Welds show signs of contamination. Have tried new argon bottle. No leaks in gas lines. Using pure and 2% thoriated tungsten, 3/32, pure...
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Sep 03, 2011 | Lincoln Precision Tig 225 Ready Pak With...
Will not weld or arc , I bought my ranger after hurricane ke ask a generator, and never elded with it. today for the first time I tried to weld with it and it will not arc
Make sure the WELD TERMINALS SWITCH is in correct position.: In the WELD TERMINALS
ON position, the output is electrically hot all the time.
In the REMOTELY CONTROLLED position, the output is
controlled by a wire feeder or amptrol device, and is electrically
off until a remote switch is depressed. If you don't have your manual, you can download one at http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=104081
Jul 18, 2010 | Lincoln Electric Ranger 305D K1727-2...
Welding Mach.front control dials are not working
go to miller .com a u will get free manual there good luck
Jun 05, 2009 | Miller Hf 251D 042388 Tig Hi Freq For...
Hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Dec 10, 2008 | Miller Hf 251D 042388 Tig Hi Freq For...
Welding Tools Logo
64 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
