I have an Toshiba A25s2792 that I want to format the hard drive and do a clean install of Windows 7. How do I get the laptop to load from the CD disk so Windows 7 can load. I've tried selecting all of the F buttons, but none work
    President:
  • 662 Answers
The Windows Startup Menu is accessed via F8 (but that's not what you want).
To access the Toshiba ROM-BIOS Menu, press F12 while powering on the laptop.
Here's an online version of your system's Users' Manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=665687&rpn=PSA20U&modelFilter=A25-S2792&selCategory=2756709&selFamily=1073768663
Posted on Mar 14, 2011
    Problem Solver:
  • 19 Answers
U have to go into BIOS & change the 1st boot device to CD rom.
Can not install windows 7
Is it the correct format? The disk must be in proper format in order to install windows 7 on it. This link should help you even further: http://pcsupport.about.com/od/windows7/ht/format-hard-drive-windows-7.htm
Apr 12, 2014 | Toshiba Portege Z930-BT9300 Customizable...
Toshiba L305-S5903 wont load Windows & due to new hard drive
Hello, Are you sure that your HDD is perfectly working good? Try formatting the harddisk and start by doing a partition. And then install good working windows OS.
Thank You.
Apr 26, 2017 | Computers & Internet
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
I want to format my c drive with the help of Dos command prompt , installed win 7 ultimate.
Formatting hard drive When booting from a Windows installation CD select the option to install Windows then you (can either delete the existing partition/s then create a new partition then you) can format the hard disk. After formatting the hard disk you can abort the Windows installation if you do not want proceed to install Windows.
You should be able to use the Windows 7 installation CD to delete the existing partition, create a new partition and format the new partition and then install Windows 7.
Apr 03, 2013 | Computers & Internet
Windows 7 not installing
All computers with minimum requirements are able to install Windows 7.
The installation CD you are using must be faulty,
use a new Windows 7 CD, and it should work.
You can also try to format your Hard Disk during the installation process to remove the old damaged Operating system files, if you are not performing a disk format, please make sure you back up all your data to a separate partition or an external drive before formatting as all your data will be deleted.
Thank you for using Fixya,
Kenneth
Jul 26, 2011 | Toshiba Satellite A105-S4254 Notebook
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
How to format my laptop
Normal 0
To format the hard disk and re-install Windows use the Windows installation CD, and the Windows Product Code on the label at the bottom of your laptop.
Boot up using the Windows installation CD and follow the instructions.
One of the installation early steps, the option to delete the existing partition, then create a new partition and then a full format on this partition (don't do a quick format) and complete the Windows installation.
Next install all of the Toshiba's computer/laptop device drives.
Next install the Windows service packs (SP2 & SP3 for XP, SP1 & SP2 for Vista)
Next Activate Windows via the Internet or by phone.
Next install your programs - Microsoft Office etc.
Next click on Start - Programs - Windows Update (for the latest updates).
Oct 16, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba A45-S121 laptop. I upgraded my hard drive from a 40GB hard drive to a 320GB Western Digital. Loaded Windows XP and formated drive in FPTS format. The computer rebooted to the hard drive...
Best possible solution put back your 40GB and try to get an external casing for your 320GB to see if it works.And try windows on NTFS instead of FPTS, so reformat your 320GB and install the Windows XP again.
I hope this solution is helpful.
Sep 26, 2010 | Toshiba Satellite A45-S121 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Computers & Internet Logo
David Payne
David Payne
