Question about Canon CLC 1150 Color Copier
Paper jam cod 0360 in clc1180 - Canon CLC 1150 Color Copier
    Guru:
  • 679 Answers
Hi
There are rollers that cling on to the paper and moved through the machine. When the rollers are worn down they do not grip the paper. You can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced
Posted on Mar 14, 2011
E0000-20-0360
This could be a DC controller issue or and issue with the black drum unit. If you have replaced the Black Drum, and it still produces the same error after doing a print, then you will need to replace the DC controller PCB and possibly look at the power supply.
Sep 18, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
Kodak apex 7000 paper jam
I have problem with my kodak appex 7000 printe paper jam the error cod coming 52
please let me know what i have to do this this problem
thanks & regards
BAVA
Jul 09, 2012 | Kodak Picture Maker Kiosk Printer
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
What Does E3 mean
E 3 means "Paper Jam". If there is no actual paper jam, but the error cod E3 is still there, it might be that something has fallen into the printer, or a piece of paper has been jammed in there. First, remove the cartridges, and turn the printer upside down and gently shake it to see if anything comes out. If nothing goes, or you can't hear anything, what you need to do is simulate a paper jam (it thinks there is one, so give it one!). Just shove a paper (120g or heavier) inside the printer (after lifting the hood up) so that a real paper jam would occur. When it starts trying to feed the paper through and its getting jammed lift the cover up and take the paper gently out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Apr 06, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Ricoh aficio 250 I justcleared a ppapaer jam in area D now the LED stills shows paper jam and machinewill not reset. I have looked good and I can not find any paper. Could I have hit a senosr or switch...
This is an older machine and I don't remember where "D" is.
Ricoh uses Optical sensors in most of their equipment so you will be lookind for what looks like 2 LEDs close together in the paper path or a actuator of some sort in the paper path that goes back to a black U shaped device (another type of optical sensor). Start in the area that you found the paper and work your way back to the tray. Since it is optical, even dust or a tiny piece of paper can cause a jam light to stay on.
Jan 20, 2010 | Ricoh Aficio 250 Copier
077-106 cod show
Open and Then Close Cover A . Open Paper Tray 5 (Bypass Tray). Clear the Paper Jam Behind Cover A
Sep 17, 2009 | Xerox CopyCentre C123 Black and White...
In CLC 1150 When power on the paper jam error show who to solve the problem in copier jam the error code shows 00-0360 0-367596
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 06, 2009 | Canon CLC 1150 Color Copier
Please, i don t know to much about copier i have a canon ir 1600 when i powor it after sometime is displaying system error E000 sos please. zakaria
i dont know more abotu copier when the copier on the paper jam error wil displayed how to solve the problem the jam Error Code :0360-0-367596
Jan 06, 2009 | Canon imageRUNNER 2000 Copier
Canon CLC 1150 Color Copier Logo
old marine
old marine
