How do i connect a 1960 rotary phone up?Which wires do i hook up? I have a blue wire &a blue white wire coming into my building,
  • 8,404 Answers
The Blue and Blue/white represent the first pair in a multi pair telephone cable. The second pair is orange the third is green and so forth. If this line is active, you will get a dial tone when you place a telephone instrument on this pair (or any subsequent live pair). Notice. If you are hanging on to the pair when the telephone rings - you will experience a 60 volt DC shock. It will not kill you but you may find it unpleasant.
On your Western Electric '500' telephone set, you should have three wires coming out of the original cable, a red, a green and a yellow. Normally, the red and the green will operate your phone on a 'private line' (only one customer on a private line). Try various combinations until you get a dial tone. You no doubt have a private line as there are very few party lines around these days if you are in the USA (and please do not say). Once up on a time, there were "party lines" where neighbors shared a line and they knew the call was for them based on the number of rings. The first customer got one ring, the second customer got two rings and so forth up th as many as 4 rings. When the telephone rang, you listened for the number of rings and answered only if it was your number. Picking up a call that was not your ring was frowned upon though it was not unknown for neighbors to listen in to other neighbors calls. It was like a reality show!
If your 500 has been upgraded with a RJ-11 wire, plug the wire in just as you would any modern telephone. If yours doesn't ring, remove the cover and study the interface. You will find several terminals marked L1, L2 etc. Move the wire you find on a "L" terminal to the various otgher L terminals until it rings when called. You may also have to adjust the spring on the ringer to get it to operate properly.
I hope this information helps you get your 1960 telephone to work.
Thank you for your interest in FixYa.com and enjoy your old telephone.
Posted on Mar 14, 2011
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
I'm installing 2 phone jacks in my newly remodeled home. We are supposed to have one phone line. Each of the boxes with phone wires in them has two cables coming out of it. In the first box, the one cable...
Pity that whoever did your remodel didn't give you a floor plan. In new construction, we make everything go to a central point. Old style was to loop everything through. It would be easy to tell, because you'd see the loops.
If you want to do this yourself, and save some money, give this a try.
The color code is that the green/red/black/yellow go to the jack. Hook all 4 wires (8 because you're going to hook both cables together to a jack) to the jack. Then, down the road, when someone has to add a second line they won't have to open this back up again. When it comes to the paired cable, look at the wires. One of the wires has more white than blue (White/Blue lead) and one has more Blue that white (blue/white lead) and so forth. You're going to be working with the blue pairs and the orange pairs, and spare out the green and brown pairs.
Strip the 4 remaining wires (the ends so they can go on the screw terminals) and connect them as follows:
White/Blue to Green Blue/White to Red White/Orange to Black Orange/White to Yellow.
If you're using Insulation displacement jack (the kind with caps where you push the wires into the slots), STOP! You're going to need more parts.
Mar 31, 2010 | Lands Phones
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Kenwood kdc-415s
if there is no amplifier separate from the radio - the blue /white wire from the back of the radio goes to the solid blue wire on the harness attached to the car's plug. the orange wire is not supported by the kenwood radio, so make sure you tape it well- if your not using a separate amp also tape up the blue/white wire coming off the harness you have coming out of the harness to the car. if this helps you please give me a good rating- if not please e-mail me at Merle840@aol.com respectfully M. Merle
Oct 13, 2008 | Kenwood KDC-415S CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Computers & Internet Logo
286 people viewed this question
David Payne
David Payne
