Question about Microsoft Computers & Internet
My burner doesn't recognize certain files in windows dvd maker, img burn etc. Plus my burner gets stuck on burning and I have to unplug the whole system and startup again to get the burning to stop.
    Master:
  • 525 Answers
Youll have to purchase better burning software. I suggest NERO as it has worked well for me for the past 7 years.
Posted on Mar 14, 2011
Which video files will Compaq DVD Burner burn to a DVD
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Apr 12, 2013 | Compaq Computers & Internet
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
I made a video from my JVC GZ-MG130 on Windows Media DVD Maker. When I try to burn to disc it fails after 99%. I tried new disc that should run at 16X but it failed again. Also, tried to run at slower...
Have you tried Nero? I want you to use the Power Cinema NE(Editor) its include in this package. Open the video file in the editor(Copy/Edit) Advance feature, you can do some editing if you wish and Produce. It will ask you what format will be the outcome(DVD Mpeg2). Once finished, this file is ready for burning. Burn it in Nero or Roxio as Data file since its already a DVD file. Hope it helps
Mar 01, 2010 | JVC Everio GZ-MG21 Camcorder
Burn cds
Hi first thing go to
start
control panel
printers and other hardware
system (on left side)
hardware
device manager
DVD / CD rom drives
does it show up as a burner? DVD-RW or CD-RW
if not it may have a wrong driver installed If windows does not recognize it as a burner it will never work untill you get past the driver issue.
If the correct driver is installed
should be pretty simple there are many ways to burn
right click on a file and select SEND TO and send it to your burner usually drive D add all your files then select BURN FILES
or if they are media files you can use Windows Media Player
if all else fails track down a copy of Nero burning rom software or Roxio easy media creator.
Finally having said all that are you using the correct media?
if you try to burn files using a DVD on a non DVD burner it won't work.
also older burners were finicky and you had to watch your + and -'s
meaning if a DVD-R isn't working then try a DVD+R
if its an older burner you may consider upgrading it, a DVD burner can be bought on ebay or newegg for about $50 and its only a 2 cable install so its not to hard.
Another more extreme solution is to save all your files which you should be keeping in the "my documents" folder and do a system restore. (requires the factory restore disks)
This is very time intensive and can be VERY tricky but if the computer has been running for 3 plus years and is running slow it could probably use a fresh start and anything that has been corrupted over the years gets wiped away.
Hope that helps
Dec 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
WHEN I BURN A MOVIE IT WON'T SHOW UP ON DVD DISC
Sounds like it may have burned the movie file as a data DVD.
In other words, the file gets burned to the DVD just like a Word doc or spreadsheet would, rather than encoded as a movie.
You need to check what format you downloaded it in - it may need conversion before burning as a movie DVD.
You can run a quick web search for *** (your current file format - mpg, divx, etc.) to DVD and find a free utility for conversion.
Then your burning software should be able to burn it as a movie DVD, ready for your player.
Aug 01, 2009 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Boot DVD
you dont need to slipstream the disc with SP 2 or SP 3 but if you want to you can following this guide :
Guide on how to slipstream windows xp with a service pack of your choice
If you get stuck let me know
But basically you create 2 folders on your C drive or on your desktop call one xp disc and the other one service pack
copy everything from the xp disc into the xp disc folder and then download and install iso buster ( download link )
And extract the img file as per the guide and then follow the burning instructions with regards to adding the img file using nero or a burning application. If you dont have nero and want to know how to use the img to make it bootable post back with what burning software you have and what version it is and I will find and post back with a relevant guide
Apr 08, 2009 | HP LightScribe dvd640i (DVD640I)...
I can't burn anything ...
download this its recommended for sp3 then try to burn again
http://www.divx.com/
Sep 09, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Can't import video into Windows Movie Maker
Windows Movie Maker is a basic video editing and creating software developed by Microsoft. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. The accepted formats for import by Windows Movie Maker are WMV, .AVI, MPG, .ASF, .WMA, .WAV, and MP3.
Puzzled about how to import DVD to Windows Movie Maker for further editing? iOrgSoft DVD Ripper can do that job. Not only rip DVD to Windows Movie Maker acceptable videos including AVI, WMV, MPEG-1, MPEG-2, ASF, but also convert DVD to MPEG-4, MOV, AVC (H.264), MOV, 3GP, FLV, SWF.
Tutorial: How to Rip DVD to Windows Movie Maker, import DVD to Windows Movie Maker?
Step1: Locate your favorite DVD to the program-DVD to Windows Movie Maker.
Step 2: Specify output video format compatible for Windows Movie Maker, like AVI.
Step 3: Click “start” button to start the process of ripping DVD movies to .AVI video.
[img]http://www.mp4kits.com/Guides/WMM/dvd-to-windows-movie-maker/importdvdtowmm/convertdvdtoavi.jpg[/img]
Aug 28, 2008 | Lite On Computers & Internet
I want to edit and burn vob files on a dvd
Nero Is not relly ment for making Dvd movies (Vob Files) You need this program click this link Download, install, and enjoy. http://tinyurl.com/2pctld
Sep 08, 2007 | Ahead Software Nero 6.0 (60045) for PC
Computers & Internet Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
