Hello there!
Your burner can't recognize CD. You should restart your computer, or try to burn different mark of CD (Verbatim, Princo, etc.).
Sincerelly,
Steve TM
Your cd drive is damage, the laser head or the spindle is not functioning and is not reading the disc thus causing the message of no cd being insert to appear, however the cd-drive power is still working which the computer is able to still detect, but like I said earlier the spindle/laser head is malfuction. You will need to replace the entire cd rom drive. If you don't know how to replace it, an external cd/dvd drive will also do the job.
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7 find me a solution
Brain,
Is your drive supports DVD? Try to put a CD disc and see its reading or not. If this problem occurs for both CD's and DVD's discs then you might have problem in your drive lense. and if it only reads CD then your drive might not be supported for DVD's.
try to clean your drive lense using CD head cleaner, it might solve your problem, other than you have to replace your drive.
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
