Question about Car Alarm Remote Starter Keyless Entry Install Cd
I have a 2000 Honda S2000. I bought it used and it came with an aftermarket alarm. It kept eating up my battery so I had the dealship take it out and replace my battery. The dead battery problem is gone for good, but I'm still without an alarm. They told me that they had problem while trying to sync my old remote transmitter to the car once the aftermarket alarm was gone, and they wanted more time and money to troubleshoot. At this point I decided to leave and just get an OEM security system later on. So I recently boubht a set of OEM security system. It turns out I have all that already installed in my car. Well since it doesn't work, I decided to just replace all the stuff with the new parts I got in the security package. I replaced everything from wire to connectors. But when I'm done, I still can't sync the new transmitters to the new alarm. I'm lost, I don't know what to do next.
  • 1 more comment
  • tonrob13 Mar 14, 2011
    What kind of alarm and model is it?
    Did you follow the instructions that came with the alarm exactly?
  • cwebyuning Mar 14, 2011
    It's the OEM security system for my model year, made by honda. I followed every step, and checked over everything. Maybe my keyless control unit fuse is blown, I'm gonna try the fuse tomorrow.
    Problem update.
    Turns out one of my fuse for the keyless door lock control unit is out. I grabbed another 15amp fuse and one of the remote start doing things.
    But then the next problem came.
    During programing I noticed at the end of the procedure only my right door lock cycle, and it continues to cycle none stop. My left door makes no sound at all and does not cycle the lock. After the programming, the right door continues to cycle as if out of control unless I manually lock my left door. At which point everything stops and never works again. I pull the fuse out and it's blown. I tried the 20amp fuse, and it does the same thing just that the fuse is ok. There was this one time I had one of the remote programmed and when I press lock the horn sounds and stuff, but right door continues to cycle to unlock. I did notice however that my dome light was on once the program ends indicating that one of the door is open, since the right door cycles I'm guessing my left door has problem recognizing itself as being closed. Any idea what I should do next?
  • 350 Answers
SOURCE: Security System Alarm Activates in damp weather
hi seems like water is getting inside the drivers door and getting on the alarm switch inside the door or it could just be afaulty alarm switch its the micro switch that connects to the door lock yatse210456
Posted on Oct 08, 2008
SOURCE: 1999 Honda Civic Remote Keyless Entry System
Hey .. i have a 99 civic also and i found my door doesnt lock unless u open the handel and then lock it and was talking to the shop and they told me things get gumed up inside and take it apart and clean it up with lub .. try that see if it works sounds like same problem
  • 3567 Answers
SOURCE: lost key for 2000 Honda Shadow 750 ACE Deluxe
Remove the ignition switch and get to the bottom of the switch. There will be two letters and two numbers if I recall correctly. The dealer can get you a new key by referencing the numbers.
Please rate this solution. Thanks!
Posted on Apr 08, 2009
  • 344 Answers
SOURCE: I installed a Bulldog remote starter RS28B. I can
The wire you are looking for is blue and it is under the driver side dash plugged into the security module
Posted on Jan 08, 2010
  • 4070 Answers
SOURCE: I have a 2005 Honda
Try using the remote and unlock the door with it then see if the alarm still goes off.
Posted on Dec 21, 2010
How can i stop the alram every time i plug in the battery off a honda accord 2000 if the alarm is not manufactured by honda
Follow the alarm speaker (Horn sounding off) wiring. It will most likely go underneath the dash. Remove the box for the aftermarket alarm and all its wiring. (Not car manufacture harness) make sure to take it all out as certain models can leave vehicle unable to start if only partial removed.
May 22, 2015 | 2000 Honda Accord
2004 hunda seat belt light stays on S2000 ?
wow malfunction junction and its 10 years old check on any recalls for it because that is a safety issue
Aug 30, 2014 | 2004 Honda S2000
Drains battery
my aftermarket alarm used to drain my battery. fixed it by removing alarm system.
Oct 10, 2013 | C3 RS6652W (NEW with 1 LCD Transmitters)...
2007 Honda S2000 I have changed the oil and installed the recommended Fram filter which is significantly smaller than the Honda filter. Problem with that? Also I have searched for the dip stick but cannot...
It is not a unsual for owners to use non oem parts for common service items. The fram filters, as long as it is listed as compatible with the ap2 (2007) s2000 will not be a problem.
Generally however, most owners will rely on oem for many of the common parts, while it is generally the various oils and lubricants in which we are more likely to use an aftermarket brand.
Here is the Honda brand filter
Honda Part# 15400-PCX-004. This is the oil filter specifically for the S2000.
here is a good website to look at in the future, it is where just about all s2k owners do their maintenance shopping.
The dipstick is fairly easy to locate, when facing the engine it is a small black rectangle on the drivers side of the engine block at the near corner.
Always check your oil after the engine has has a chance to cool completely and is parked on level groud.
FYI the difference in oil between the lowest line on the dipstick and the high line of the dipstick is appox 1 quart of oil.
Finally you should always remember to replace the oil drain plug washer with a new one every time you change the oil as it is a one time use part. THey are available at the website I listed above.
Hope this helps.
Oct 31, 2010 | 2007 Honda S2000 Convertible
Honda s2000 wiring diagram
my 100a fuse in the fuse box under my bonnet keeps popping when i try to jump start my car :( i just bought a new fuse and a new batt but havnt fitted them yet as have to wait for them to come in, but could there be another fault?
May 20, 2010 | 2001 Honda S2000
My battery went dead bought new battery now alar system wontb let car stat an alarm keeps going off
since the alarm is sounding I am assuming this is an aftermarket alarm system
if it where the factory system the vehicle would not start but the alarm shouldn't sound
do you have a little red light on the dash flashing somewhere....if so then there is a kill switch somewhere on the vehicle... look under the dash
Jan 04, 2010 | 2000 Cadillac DeVille
sounds like a bad starter selnoid or starter drive
Feb 18, 2009 | 2002 Honda S2000
Honda S2000 Year 2000, Boot Flip has stopped working
first check the fuse to the boot actuator if its ok it will most likeky be the actuator itself.
please leave feedback.
Jul 01, 2008 | 2000 Honda S2000
Car Alarm Remote Starter Keyless Entry Install Cd Logo
128 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
