Because it is daylight savings time today, how do I re-set the time on my TV model 32LD350?
Use your remote...
1) Hit "Menu", use the buttons to select "Time," then press "Enter" 2) Select "Clock," then hit "Enter" 3) Select "Manual"
If your clock is exactly 1 hour behind
4) Go to "Daylight Savings" and select "On" 5) Hit "Back" to go to the previous menu 6) Select "Exit"
Posted on Mar 14, 2011
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
How to set time on GPS watch
From your comment I have no idea what watch you have! The more infromation you provide, the likelier it is we will have a solution. However, in general, watches cannot tell if you live in a spot on the globe that uses daylight savings time. You have to enter that information. Go into your settings and see if you can turn on Daylight Savings. The watch should set the time automatically at some point, occasionally takes some time. Only a part of the world uses daylight savings, invented by Ben Franklin to save energy(coal oil) just like today!
Nov 07, 2011 | Citizen Watches
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Oct 29, 2007 | Emerson Smartset Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSetĀ® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSetĀ® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSetĀ® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
