Remove your Canon printer from the PC and uninstall the printer software. Now reinstall the printer software which is downloaded fromt he website or from the disc.Only then you must connect the Printer which will be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
You may want to try the following link:
http://software.canon-europe.com/products/0000524.asp
You will need to choose the appropriate Operating System
I do hope this helps.
Best of luck!!
Your printer will not run under Windows 7. Check this out: http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Hardware&s=Canon%20LBP%201120
Microsoft publishes this Hardware and Software compatability list with each new Operating System they release. MS encourages upgraders and new computer purchasers to review this list so they will not be surprised when something doens't work.
I'm sorry to be the bearer of this news ... Time to upgrade upir printer.
Thanks for your interest in FixYa.com
SOURCE: vista driver for canon cp 300 printer
if Vista and 7 is unsupported by the printer manufacturer, you are pretty much out of luck. If Vista and 7 say the printer is unsupported or un certified, run the manufacturer software if you want.
You doult run in emulate mode ... but for as cheap as printers are these days, why would you want to run in that mode?
SOURCE: I am having problems installing canon iP5200 with Windows 7
Did you upgrade the computer from Windows XP to Windows 7? If so, did you uninstall the driver before you did the upgrade? The old driver files may be causing the problem.
To fix, go to this link, and in the search box in the center of the screen type "windows 7" and click on the Search button. Then select the link "ERROR: Cannot communicate with the printer after upgrading to Windows 7". There will be step-by-step directions for resolving your problem.
Testimonial: "Thanks for your suggestion. I ended trying the following before your post - deleting device and reinstalling. Cheers Stuart "
SOURCE: Windows 7 printer driver for Canon Pima MP510
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system (Windows 7) of your computer and download the appropriate drivers and software.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: Driver for Canon S200spx printer for Windows 7
Here's the direct link. http://www.opendrivers.com/driver/2118168/canon-s200-inkjet-printer-driver-add-on-module-1.10-windows-7(all-x32-x64)-free-download.html Just enter the Captcha and download. Good luck
SOURCE: imageCLASS MF4150 All-In-One Laser Printer: canon mf4150 Windows driver install win 7...
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay klmsd
