Question about Dishwashers
Lost the template to fix the intergrated door to a smeg sth 903 dishwasher
4 Suggested Answers
  • 121 Answers
SOURCE: Smeg Intergrated Dishwasher
Do any objects hang down (or stick up from below) and block it? Is the shelf pushed all the way in so it gets water through it? Does it seem to be spraying water, but not spinning?
Try spinning it by hand to see if it moves freely. It may just be blockede by a small object in the water.
Posted on Nov 07, 2007
SOURCE: SMEG DISHWASHER - SUPPLIER CODE : SA8605XTD
Hi, I don't usually put the tablet in the door holder. I just place it in the bottom of the washer . I aways am concerned that there will be soap residue. So this way utensils are getting washed as soon a the washer commences .I usually scrape debris off plates and utensils before I put them in the dishwasher. This works well. Hope this works well for you. Teresa
Posted on Apr 19, 2008
SOURCE: i have neff intergrated dishwasher, but the door
When you open the dishwasher door you will see three screws along each edge. You need to remove the middle screws and replace them with longer ones that will go into the door front as well.
Posted on Mar 08, 2009
Smeg dishwasher leaking from front right hand side, cold leak
The door seal may need replacement, the hot water may soften the seal and fix the leak.
Feb 23, 2015 | Smeg Dishwashers
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
The machine starts, does not heat the water, and just continues to run unless turned off manually. I am thinking either the timer or the heating element has failed. The machine is a model with the control...
hi test the element,the wires in the door can also break,it may be a thermostat/thermistor.if all these test ok it may be the pcb which is known as an intergrated these boards can be very expensive.
Jun 02, 2010 | Smeg 24 in. STX2 Built-in Dishwasher
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Smeg SA 8210X, manual
You can find basic instructions here below, contact Smeg for a replacement manual.
SA8210X
Mar 25, 2009 | Smeg Dishwashers
Oct 08, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Apr 21, 2007 | Smeg DWI614 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
