I have SONY BRAVIA KLV-32BX300 TV and I had a problem connecting it with my pc, I tried the VGA cable and the pc with another monitor and it worked fine, so I tried doing a firmware upgrade and followed the instructions posted in sony.com to download and install the firmware version 1.148 (if I can remember), but it never turned on again, and the only thing that I can see are the three front leds (standby, power and timer) blinking together once per second, please help! I've searched online and I can't find the problem and Im desperate!! please help!!
  • j_m_alvarez_ Mar 14, 2011
    I would like to try that by my tv doesnt want to turn on, its just stucked with the three leds blinking and no response from it, Ive pressed the power button from the TV itself and the remote control, and none of them seems to work
    Problem Solver:
  • 10 Answers
This is indicative of a bad flash; I would recommend formatting your USB stick (FAT32), redownload the pkg update (available here: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25 ), and performing a firmware upgrade again.
Taken from: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25
  1. Turn the TV on.
  2. Insert the USB storage device into the USB port on the back of the TV.
    Note: The USB storage device can only be inserted into the USB port slot one way.
  3. Turn your TV off by pressing the power button on the TV
  4. Press the POWER button again. The POWER indicator will be green for 30 seconds, followed by the PIC OFF/TIMER indicator slowly flashing amber, and the STANDBY indicator is red.
  5. After several minutes, the TV will turn off and then turn back on to complete the update.
  6. Remove the USB device from the TV.
Posted on Mar 14, 2011
Testimonial: "you are amazing my friend! the only thing I had to do was reformat my flash drive, but not a single format, a low level one, tried again and it worked"
  • NickDW Mar 14, 2011
    I'd suggest unplugging it from the wall for ~20 seconds. If it still gives you the blinking lights, you can attempt to reflash it again by formatting a USB stick, copying over the firmware pkg, and inserting it prior to plugging it back in; but it's very likely you'll have to take it in for service; as the only mode of recovery is either an undocumented failsafe flashing method, or by means of a JTAG (Requires disassembly of the LCD and technical expertise)
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Colored line in sony klv-32Bx300
It would probably cost more to fix than it would to buy a new one.
Mar 14, 2014 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Screen haf good haf no good
Replace entire monitor..Cheaper to by new..
Oct 08, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Screen problem
Cheapest way out.. Buy new monitor..
I have sony LCD Tv klv-32bx300.when turn on the tv sutenly power getting standby.what is the resan?
I have a tv sony lcd klv32bx300 when turning on works for about 15mins then sfhuting down and blinks 3times the red led on standby signal . Then stop for 2sec and again blinks 3times. I bought this tv in the middle east but we are h ere now in phils. I br ought this problem here in sony service center but the cost to repair this problem is half of the price when i bought. Any one can help to fix this problem
Aug 31, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Red light flashes 5times continuously doesn't power on started last night
try unplugging it from the power outlet, hold and press its power on switch for 10 seconds, and test it again. you may also want to try another power outlet.
Aug 08, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Televison & Video Logo
1,108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
